SPARK PLUG WIRE CHANGE
Old Feb 23, 2008 | 11:54 AM
profinish's Avatar
profinish
Default SPARK PLUG WIRE CHANGE
I was thinking about changing out my stock plug wires for aftermarket 'red' ones to match my bike. How easy is the swap and is there any benefit other than looks to doing so.
Old Feb 23, 2008 | 11:56 AM
etrader's Avatar
etrader
Default RE: SPARK PLUG WIRE CHANGE
SE ORANGE below...exclusive boot design ensures positive coil connection...8mm wires transmit max voltage to fire plugs...EASY SWAP...with the tank off![8D] Good excuse to do a motor build.
Old Feb 23, 2008 | 12:10 PM
PEZ's Avatar
PEZ
Some aftermarket plug wires look cool, but have poor noise rejection (Shielding) which I have seen cause problems with the radio, and amps when present........
PEZ
Old Feb 23, 2008 | 12:40 PM
pled55's Avatar
pled55
how aboutnology wires on an 05 king stage one
will these affect the ecm or anything like that ?
Old Feb 23, 2008 | 03:18 PM
PEZ's Avatar
PEZ
I remember seeing a show on making the VROD wher HD was inducung LOADS of RF into the bike to make sure the ECM etc would be OK--Im pretty sure the ECM wll be fine if the shielding isnt quite as good as stock
I had one instance where a fellow put our amp in and was having a strange noise issue after a few minutes--after 3 amps etc etc etc and the fellow sending his radio in for service, I found out he had changed to "gucci" looking plug leads. After almost 3 months of greif for both of us, he put his stock leads on, and problem was GONE. Not having tested all the brands of leads out there, I cant say what the blanket results will be----but in this one case, it was painfull.........
PEZ
Old Feb 23, 2008 | 04:22 PM
mtclassic's Avatar
mtclassic
SE plug wires come in red and they won't throw codes and they are cheap. I think they are $12
Old Feb 23, 2008 | 05:10 PM
bulldogmoe7's Avatar
bulldogmoe7
exchange my stock plugs for the screamin eagle 8mm takes a litle time to reroute without taking the tank off. but it can be done
Old Feb 23, 2008 | 05:21 PM
vettedog72's Avatar
vettedog72
I saw a bike with some kind of lights that looked like lightning, kinda orange/yellow lightning bolts. They "struck" each time the plug fired. It was on a custom and looked great. The color of the wires never registered.
Old Feb 24, 2008 | 05:00 AM
PapaTravis's Avatar
PapaTravis
I have seen some neon ones through Dr Neon. http://www.drneon.net/and, I just stumbled upon, http://www.neonhotwires.com/. Pretty cool IMO...
elmo4fun
EVO
May 13, 2018 11:49 AM
apetterez
Dec 12, 2014 11:30 PM
peddler
Sep 20, 2013 06:34 PM
jj3030
Sep 21, 2010 10:43 PM
07yellowglide
Feb 25, 2008 05:37 PM
