Fairing Wings
Old Jun 17, 2008 | 12:01 AM
  #31
ratcat's Avatar
ratcat
Default RE: Fairing Wings
The new vents not only block a lot of air to stay warm, but when the engine is gettin warm and workin hard climbing a long mountian pass, you can turn the vents to blow the air on the heads.
Old Jun 17, 2008 | 12:22 AM
  #32
continentaldrifter's Avatar
continentaldrifter
yes it has been done...all thats required is another machine screw, drill the hole, go to ACE hardware and buy two .5 x .5 poly washers with a 1/4 x 20 hole, grind one end down to 45degrees and bolt up.no biggie.....if need pics lemme know....................is it worth the fuss?? honestly the difference was very slight.&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nbsp\\;&nb sp\\; 2 pence
Old Jun 17, 2008 | 06:33 AM
  #33
viperpaul's Avatar
viperpaul
So how does these fit my SG has three plastic buttons and one screw at the top, is it threaded behind the push in buttons.
&nbsp\\;
HD are rubbish in the UKno one can tell me what fits which bike, and the HD catalogue so badly need updating
Old Jun 17, 2008 | 06:52 AM
  #34
Gem99Ultra's Avatar
Gem99Ultra
+1 on Freedom Wings. Fit perfect, work perfect, look perfect. Inexpensive.
Old Jun 17, 2008 | 12:05 PM
  #35
iclick's Avatar
iclick
Speedster, I would answer, but I can't post anything more than one line.
Old Jun 17, 2008 | 01:22 PM
  #36
VicDawg's Avatar
VicDawg
I just put an 08 inner fairing on my 07 - problem solved. (actually I bought an&nbsp\\;08 inner fairing by mistake to have painted and put on my bike to minimize downtime, realized my mistake when I saw a hole was missing on the right side for the brake and switch cables and had to cut one with a Dremel tool), but the new style HD fairing wings work - LOL.
Old Jun 20, 2008 | 08:34 PM
  #37
stro1965's Avatar
stro1965
ORIGINAL: continentaldrifter
yes it has been done...all thats required is another machine screw, drill the hole, go to ACE hardware and buy two .5 x .5 poly washers with a 1/4 x 20 hole, grind one end down to 45degrees and bolt up.no biggie.....if need pics lemme know....................is it worth the fuss?? honestly the difference was very slight.&nbsp\\;\\\\\\;&nbsp\\;\\\\\\;&nbsp\\;\\\\\ \;&nbsp\\;\\\\\\;&nbsp\\;\\\\\\;&nbsp\\;\\\\\\; 2 pence
&nbsp\\;
I drilled the 4th hole and put a nut on the backside.&nbsp\\; Just that easy.&nbsp\\; I really am impressed, big improvement over the stock non-adjustable ones I had.&nbsp\\; And they look WAY better.&nbsp\\; Especially when you have&nbsp\\;a dark shield.&nbsp\\;
Old Jun 21, 2008 | 01:22 PM
  #38
peddler's Avatar
peddler
If I undersatnd correctly to remove the adjustable wings you have to remove the outer fairing to temove the 4th nut
&nbsp\\;
Yes
No
Old Jun 21, 2008 | 07:40 PM
  #39
stro1965's Avatar
stro1965
ORIGINAL: peddler
&nbsp\\;\\\\\\;
Yes
No
&nbsp\\;
Yes, but I never took the stock ones off anyway.&nbsp\\; Can't imagine why I'd want to pull these off.
jrdfatboy
Mar 20, 2012 05:45 AM
Nellybelle
Jan 2, 2011 08:45 PM
rookiedan
Sep 11, 2009 12:03 PM
Buzzsaw
Nov 29, 2008 11:32 PM
peddler
Oct 9, 2008 09:36 AM
