how does the key knob come off
Old Jun 23, 2008 | 08:17 PM
84 softy's Avatar
84 softy
Default how does the key **** come off
I haven't bought a manual yet but I'm 2/3rds done on the tear down from hell.. lot's of parts on these ultra's
Old Jun 23, 2008 | 08:41 PM
dionne51's Avatar
dionne51
Default RE: how does the key **** come off
There were some pretty good posts on how to do that from my readings last year.&nbsp\\; I won't give you the 'get the manual' line as you're hopefully well aware of that.
&nbsp\\;
Try some searches on the forums for it, I'll do the same and report back if I find it.
&nbsp\\;
D
Old Jun 23, 2008 | 08:42 PM
dionne51's Avatar
dionne51
Here's one.......
https://www.hdforums.com/m_2966650/tm.htm
Old Jun 23, 2008 | 08:48 PM
dionne51's Avatar
dionne51
and an exerpt from another post\\;
7. Remove the fairing cap and the ignition switch.
&nbsp\\; a. Turn the forks all the way to the left.
&nbsp\\; b. Look under the fairing cap (that's the plastic piece under the ignition switch that has places for 4 switches) and unplug the wiring harness.
&nbsp\\; c. Insert the key. Turn the ignition to unlock. Turn the ignition to fork lock.
&nbsp\\; d. Depress the release button on the bottom left of the ignition, push the key down and turn the key 60 degrees counter-clockwise.
&nbsp\\; e. Lift and remove the ignition ****. A spring will fall out of the ****.
&nbsp\\; f. Remove the nut (7/8") and spacer. You may have to turn the forks to the right to get at it.
&nbsp\\; g. Remove 2 screws (torx) from the fairing cap. 1 on each side.
&nbsp\\; h. Remove the fairing cap.
Old Jun 23, 2008 | 09:12 PM
vindyl's Avatar
vindyl
and what ever you do do not turn the key after you remove the ignition from the bike
Old Jun 24, 2008 | 06:55 PM
84 softy's Avatar
84 softy
wow that's alot of steps.. but I'll give it a try in the next day of so when the new bars are here..
thanks for the help
Larry
Old Jun 24, 2008 | 07:01 PM
bigirn's Avatar
bigirn
its not that bad. but like vindyl said dont remove the key.
Old Jun 24, 2008 | 07:30 PM
gambler's Avatar
gambler
Here is a good step by step pictorial.
http://www.kenandjudy.us/Motorcycles...new_page_1.htm
Good luck.
lkman111
Jul 27, 2008 11:59 AM
Edgeflhtci
Jul 18, 2008 05:21 PM
reecard
Jul 11, 2008 09:40 AM
deadman77
Jun 25, 2008 05:18 AM
loudguy_w_louderpipe
Jun 13, 2008 08:55 PM
