Shift linkage rod ends - again
Old Jan 4, 2009 | 09:41 PM
vette8494's Avatar
vette8494
Default Shift linkage rod ends - again
In most all of the threads regarding the HD rod ends everyone suggests changing them to a Heim rod end. I went to the Heim web site and found many parts with different prices. Does anyone know the correct model # and what a good price is?
Old Jan 4, 2009 | 09:52 PM
Scorpion07's Avatar
Scorpion07
http://www.midwestcontrol.com/buy.php?item=308
Someone else here got me to this site.
I used stainless and polished them. Made my own polished stainless rod too.
looks nice.
Old Jan 4, 2009 | 10:03 PM
vette8494's Avatar
vette8494
Thanks Scorpion07. This really helps. I'm going to order 4.
Old Jan 4, 2009 | 10:16 PM
Scorpion07's Avatar
Scorpion07
Vette8494, Unless you're going to make two sets - 2 would be good. These things will not wear out in this application.
Old Jan 4, 2009 | 10:29 PM
vette8494's Avatar
vette8494
You said you made your own rod. Will the one on the URL you sent work with the HD rod?
Old Jan 4, 2009 | 11:30 PM
skratch's Avatar
skratch
i got mine from race_basics on ebay. paid 8.00 and some change for 2 and shipping.
here's a link to one of their auctions, http://cgi.ebay.com/ebaymotors/Heim-Joint-Rod-End-5-16-Righthand-Female-NEW_W0QQcmdZViewItemQQcategoryZ42609QQihZ017QQitem Z270313830043QQrdZ1QQ
sspagenameZWDVW
you can use your existing shift rod, get 2 of these heim joints, and you will also need 2 jam nuts, 5/16 - 24, and 2 bolts, and 1 nylon lock nut. so for less than 10 bucks, you can have yourself a shift linkage that will probably last longer than your bike.
Old Jan 5, 2009 | 10:18 PM
vividflhx's Avatar
vividflhx
5th Gear
Default linkage and rod ends
i replaced my linkage with 1 i made, kept the stock ends since they keep the linkage centred and not sagging off verticle, check the linkage i made and a few others i have made
https://accounts.craigslist.org/post...77888181&db=lv
Old Jan 5, 2009 | 10:42 PM
Beemervet's Avatar
Beemervet
Good luck with that. It's the ends that fail. Old problem that HD won't address.
Old Jan 5, 2009 | 11:52 PM
6 gun's Avatar
6 gun
After being stranded 2 times in the middle of nowhere I bought
the round polished stainless steel gear shift linkage #33814-98A
for around 80 bucks. Right after I traded bikes I put the same thing
on my new rkc before it ever left the building. I hate being stranded
Old Jan 6, 2009 | 05:00 AM
XTrooper3936's Avatar
XTrooper3936
You've got this bass-ackwards. It's the flimsy front OEM linkage end that most often fails. There's nothing wrong with the linkage rod itself.
