Dyno results - 05 Ultra
Old May 4, 2006 | 11:15 PM
dchoran's Avatar
dchoran
Default Dyno results - 05 Ultra
Taking the scoot in to the stealership for a Dyno at 8am tomorrow - hope to have the popping, backfiring and lousy 32 MPG fixed (stock was 42+).
ANY TIPS FROM THE EXPERTS??? WHAT SHOULD I WATCH FOR???
Right now I have the exact recommended Dynojet map for my setup, but it has got to be way too rich.
THANKS.
Old May 5, 2006 | 12:06 AM
bay13's Avatar
bay13
Default RE: Dyno in 12 hours - any tips???
Make sure you have a full tank of High test.
Old May 5, 2006 | 01:15 AM
bountyhunter's Avatar
bountyhunter
Just hope the tech is not a rookie tuner!
Old May 5, 2006 | 07:10 AM
HD Renegade's Avatar
HD Renegade
Make dam sure you tell them how you want the bike to run. In other words tell them you optimal mpg in the cruise range of 1800 to 3000 rpm. Tell them this up front.
Bob
Old May 5, 2006 | 04:04 PM
Kahuna's Avatar
Kahuna
From what I've seen on several dyno charts of a TC88 engine, with tru dual exhaust, your numbers should be somewhere in these ranges:
HP: between 74 to 78HP
TQ: between 75 to 81
Fuel/Air: between 13 to 14.5
Your numbers may vary outside of these ranges, depending on the equipment you have on your bike. I'm assuming you have either a PCIII or SERT too?
Good luck,
Kahuna
ORIGINAL: dchoran
THANKS.
Old May 5, 2006 | 09:24 PM
dchoran's Avatar
dchoran
Default 05 Ultra Dyno Results are in
Not too bad - took 2 hours @ $70/hour - don't feel like I got screwed by the stealership at all. Hmmmmm. Maybe they all just know me too well by now.
The PCIII map I had was Dynojet's EXACT map for my EXACT setup - but it seemed very very rich (could smell it) and she backfired occasionally.
Runs slightly better now with the dealer's tweaks. If interested in the maps/graphs, send me an email. I'M HAPPY SO FAR - better get at least 40 mpg (vs. 34)!!!!!
HP/TQ curves are almost superimposed with some difference from 3500 rpm and up. Wasn't expecting too much since that M807-163.djm was Dynojet's map (best one?).
HP = 69.06 to 72.29 TQ = 76.00 to 78.67 AF = was ~ 12.5 @ 3500 to 5500 - boosted to 13.35.
They really cut back on the fuel across the 5% to 20% throttle positions without any noticable loss in performance. I think that is the area that will help my MPG hopefully.
They also adjusted the ignition timing map between 2000 and 4000 rpm @ 0% + 2% throttle - my guess is to reduce the decel popping. Decel pop still there but not as loud.
Almost seems like we could make changes to these maps ourselves to get trial and error results - anybody out there do this???
Let me know what you guys think of the above stuff - typical, screw job or decent??? THANKS ALLOT Dave H. Appleton, WI
Old May 6, 2006 | 12:18 AM
Topper's Avatar
Topper
Default RE: 05 Ultra Dyno Results are in
Looks like you had a good experience Dave, numbers look good.......I was getting a slight bit of popping with the SE slipons, none since I went to the 2-1 pipe. My last dyno had my ATF at 17 between 2000-3000 rpm's yet getting better MPG than stock and Stage 1. No real set in stone answer for anyone with these EFI bikes, I'm happy, you seem to be happy, so it seems its time to ride
And by the way, no carbon build up what so ever on the end of my pipe, I thought that the 17 would have to be adjusted but after 300 miles and no carbon (which is unheard of, IMO) the tuner may have hit the nail on the head with my map.
Old May 6, 2006 | 12:57 PM
BigLeesFLHPI's Avatar
BigLeesFLHPI
3rd Gear
Default RE: Dyno results - 05 Ultra
Taking my bike in on the 16 th, dealer says it will take 6 hours of dyno time after installing V&H true duals, V&H slip ons stage 1 and sert. , does that sound like a reasonable time?
Yrdomingo
Jul 25, 2012 05:29 PM
HDCrossbones09
Jan 5, 2012 05:22 PM
Foodog
Aug 13, 2011 06:42 AM
jaysonL
Jul 17, 2010 12:45 AM
JimmySG
Dec 5, 2007 03:45 PM
