New Shifter Peg Install Question
Old May 7, 2006 | 10:57 PM
johnnyig's Avatar
johnnyig
Default New Shifter Peg Install Question
Hi All, as upgrades continue forward, I have purchased some new shifter pegs to replace the rubber ones on my 06 RKC. Question is I dont see how the old ones come off. The outside end is rubber and there doesnt seem to be a bolt head on the end facing the motor? Any help would be appreciated. -John
Old May 7, 2006 | 11:00 PM
Topper's Avatar
Topper
Default RE: New Shifter Peg Install Question
Channel locks and twist, lefty = loosen, OEM pegs are useless so don't worry about damaging the rubber.
Old May 7, 2006 | 11:01 PM
SubZer0's Avatar
SubZer0
Cut the rubber off and use a pair of vicegrips. Thats what I had to do.
Old May 7, 2006 | 11:42 PM
Lpye's Avatar
Lpye
I used vice grips on the rubber and remover mine with no problem.
Old May 7, 2006 | 11:52 PM
vegashd's Avatar
vegashd
I did the same, channellocks on the rubber and spun her off. The rear one came off easier then the front one though. But both were not to difficult.
Old May 8, 2006 | 12:23 AM
Big Ted's Avatar
Big Ted
Me too! Channel Locks did the trick.
Old May 8, 2006 | 08:37 AM
Abnmarine's Avatar
Abnmarine
Buy billet shift levers and remove them with the pegs. That is what I did. Otherwise, use some plyers.
Old May 8, 2006 | 12:03 PM
jerseyjeff62's Avatar
jerseyjeff62
use the channel locks on the rubber close to lever.they're loaded up with locktite so they will fight you a little bit
bulldog896
Feb 16, 2013 12:16 AM
Billie
Jun 19, 2009 09:14 AM
Dbl B
Jun 16, 2008 10:55 PM
Streetrunner
Jan 22, 2007 10:04 AM
Dunk 2
Nov 27, 2006 10:13 PM
