Security System Key FOB Distance
Old Aug 1, 2009 | 06:15 AM
Tx_Rider's Avatar
Tx_Rider
Default Security System Key FOB Distance
I tried searching but didn't find an answer here or in the manual.
What is the distance on the Security system key FOB?
I leave my house keys and FOB on a table inside the front door and the bike is out in the driveway about 20' away, I want to make sure it isn't able to start from that distance. (I know, go test it out, but I was curious of the distance)
Old Aug 1, 2009 | 06:19 AM
Jinks's Avatar
Jinks
5 to 6 feet. I sometimes leave my keys on the bench in my shop & have occasionally moved the bike thinking I have them in my pocket. That alarm can be real annoying even in the few seconds it takes to get the keys close enough to kill it!
Old Aug 1, 2009 | 06:24 AM
JayStronghawk's Avatar
JayStronghawk
My guess would be 10 feet but won't argue about it .. One thing for sure if someone is trying to hot wire your Bike throw your keyfob down before trying to run him down LOL
Old Aug 1, 2009 | 06:59 AM
Bowhunter61's Avatar
Bowhunter61
+1, I agree with JayStrong on the 10 feet. I did some experimenting with this when I first got the bike because the Key FOBs were not programmed (at that time it was infinite ), so when I did get them programmed I checked it out and after about 10.5 feet on mine the bike wouldn't start and the alarm was a flashing. Might also depend on walls and such, my test was out in the open.
Old Aug 1, 2009 | 07:04 AM
shortride's Avatar
shortride
I tested mine after installing a Siren II and it's about 10 feet. Now I have to figure out the Remote Pager Receiver.
Old Aug 1, 2009 | 07:12 AM
bellgnte's Avatar
bellgnte
Depends how good the battery is in the FOB
Old Aug 1, 2009 | 07:14 AM
Mr. Wizard's Avatar
Mr. Wizard
Jay.. I think you got it down.
Two things will affect the range though... strength of the fob battery and the location of the security antenna that is located under the seat or behind the left side cover. It's about 2.5" long and 3/4" square.
While changing my trike battery last night I noticed the antenna had jumped off of its peg mount and fell behind the battery casing/frame. Had thought my fob battery was weak but the signal was being blocked. The range went up from having to be within 2 feet to about 10.
Old Aug 1, 2009 | 07:23 AM
tibadoe's Avatar
tibadoe
I never really thought about the distance..........checked mine and 10ft is about right.
Choppie
Feb 4, 2019 03:10 PM
predatornut
Mar 22, 2015 04:31 PM
flyboyron
May 2, 2014 10:09 AM
MSG Hall
May 29, 2012 12:56 PM
lbrty9
May 15, 2007 08:56 AM
