Wide White Wall Tire Options???
Old Oct 12, 2009 | 05:15 PM
jcbpa's Avatar
jcbpa
Default Wide White Wall Tire Options???
Need to repalce the tires on my 08 FLHRC. I really like the Wide White wall look, but wonder if there is a better brand than the OEM. I got 15,000 on the front, and the rear only has 6000 on it but I must have picked up a piece of glass and there is an ugly slice in it. When I changed the OEM wheels I stayed with the original size....
front mt90 B16
rear mu85 B16
Any advice would be appreciated.
Old Oct 12, 2009 | 06:03 PM
Bluegrasser's Avatar
Bluegrasser
Metzeler ME880's are probably the most popular non-OEM WWW replacement.
Old Oct 13, 2009 | 09:41 AM
electra glide's Avatar
electra glide
The Metzlers re nice, good feel supposedly. I don't know as I never tried them out. I've always stuck with the Dunlops cause of the wear issue. The Metzlers are a softer compound and as a result seem to "stick" better, but also will seem to wear faster. I'm not ripping my bagger at high speeds through tight twisties, so the wear issue is the deal breaker for me.
Old Oct 13, 2009 | 09:42 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Avons are nice as well. If you want high mileage check out the Avon gangsta whitewalls, although the tread pattern suck IMO. The Venom WWW seem to work fine for us. Not to mention that We have read about the Metzler whitewalls turning brown rather quickly.
Old Oct 13, 2009 | 12:04 PM
billross77's Avatar
billross77
I will always ride with Metzler. They are a little more round, so it takes a few days to get used to, but it is a much better handling tire, IMO.
Old Oct 13, 2009 | 01:16 PM
gunner11's Avatar
gunner11
Hate whitwalls, too hard to keep clean, and I'm too lazy to do it. Blackwall all the way for me.
Old Oct 14, 2009 | 10:19 AM
Peppa1's Avatar
Peppa1
I've run the Dunlop white walls on several of my RK's and had great results. The only reason I went away from Dunlops is because of the wheel sizes that I have now and Dunlop doesn't make a tire to fit. I wish they did !!!
Old Oct 16, 2009 | 10:55 PM
BK Meyers's Avatar
BK Meyers
Default Metzeler
I run the Metzeler ME 880's front and rear on my '96 Road King. Normally get 10K out of a rear tire and am currently at 23K on my front tire and it still has good tread.
Whatever tire you choose be sure to go with the manufacturers recommendation on tire pressure(s).
Later,
BK
Uberjason
2014-2024 Touring Models
Apr 8, 2017 08:33 AM
NBK
Wheels/Tires
Feb 17, 2017 12:08 PM
bikerlaw
Sep 1, 2013 08:00 PM
superglidezak
Mar 1, 2012 04:39 AM
youngrider
Nov 4, 2008 03:50 PM
