WIX filters, FYI......
Old Aug 17, 2022 | 08:21 AM
  #41
mike131's Avatar
mike131
Originally Posted by Tired
What do you like about them?
The way they are built on the inside quality made, at least they use to be, haven't cut one open in a long time, been around a long time, here this sums it up, Developed and manufactured to very high specifications to exceed the demands of modern racing engines and extreme racing conditions, the Hiflofiltro RC range provides numerous advantages for both road user and track racer.
  • 17mm cross drilled nut enabling easy removal and lock wiring for race use
  • Advanced high performance tri-fiber filtration media for optimum filtration, high capacity, and improved oil flow. Capable of capturing particles as small as 5 microns.
  • Tough heavy duty steel canister capable of withstanding extreme pressure
  • Special fibre or rubber coated relief valve for perfect sealing
  • Compatible with all oil types, mineral and synthetic
Old Aug 17, 2022 | 12:42 PM
  #42
davenay67's Avatar
davenay67
What Is a Micron?
A micron is a unit of measurement that is 0.001 millimeters or 0.000039 inches. For example, bacteria are 2 to 3 microns in diameter and a red blood cell is 5 microns. The diameter of human hair averages 70 to 80 microns.
Old Aug 17, 2022 | 01:29 PM
  #43
NorthWestern's Avatar
NorthWestern
Originally Posted by stroker23
A few years WIX filters were bought out by MANN Corp. (Germany) in case it's relevant.
Wix are great. I run them in just about everything. I have the Amoil, and S&S filters on my shelf as well.
I have cut open 100s of filters at work, diagnosing engine failures, and all this new business in recent threads about FRAM being superior will never change my mind about the lack in quality I have seen in years past from FRAM.
Wix builds a great filter, and Mann does as well.
Old Aug 17, 2022 | 05:20 PM
  #44
hattitude's Avatar
hattitude
I remember back in the 70's, I built a 289 engine in my '67 Mustang, and then a 330 engine in my '64 Olds 442.... They were done years apart and I used two different shops for the head work. Both shops warned me against using FRAM oil filters... I have never trusted them since those warnings...
Maybe FRAM has completely turned around their quality, or maybe they were never that bad in the first place.... But old habits die hard.. I'll never use them...
I use WIx on my cars (I have used Mann on my wife's Mercedes), Wix or Baldwin on my diesel boats, and HifloFiltro on my Harleys.... I have no need to entertain using a FRAM filter...
lt1tyrell
Oil Archive (no new posts)
30
Aug 19, 2015 06:55 AM
gdt3
Apr 3, 2014 07:20 AM
All Aces
Aug 5, 2010 04:48 PM
Thunderchild
Feb 17, 2008 07:35 PM
skratch
Exhaust System Topics
Feb 24, 2007 07:55 AM
