Hawg wired handlebars controls didn't work when I woke the bike up
Old Mar 6, 2010 | 05:54 AM
Mike5959's Avatar
Mike5959
Default Hawg wired handlebars controls didn't work when I woke the bike up
My battery died once over the winter. I have had it on a tender since I jumped t. Today I take her ou and my handlebar cntrols aren working the alpine. How do u reset? Do I need to drop the fairings or is there another trick?
Old Mar 6, 2010 | 06:48 AM
r8rs4lf's Avatar
r8rs4lf
Kinda off topic, but did you install that handlebar control kit yourself? If so, how hard was it? How well does it work?
Old Mar 6, 2010 | 08:24 AM
Badbagger's Avatar
Badbagger
Off topic continued lol. Installed the Sony kit and new HU two weeks ago. Works like a charm and a walk in the park to install.
To the OP: Double check all of your connections in the fairing etc to be certain that nothing has come loose and when you ur in there, I'd put some die electric grease on your connections. The handle bar controls aren't HW.. still Moco obviously but if all of your HW connections are good and zero issues, ask yourself what else has changed if anything aside from the obvious.
Old Mar 6, 2010 | 04:22 PM
Harleypingman's Avatar
Harleypingman
If you jumped the bike using a car with the car's engine running, you may have damaged the bike's electronics.
Biketronics suggests disconnecting the negative battery termnal for five minutes or so. I have no idea what this accomplishes, but it's part of some reset procedure. Perhaps that will work with the HW interface module also.
Hope you find a solution soon.
Carl
Old Mar 6, 2010 | 04:29 PM
Mike5959's Avatar
Mike5959
I used a Harley battery charger. Everything works except the handlebar controls.
Old Mar 6, 2010 | 04:32 PM
Harleypingman
There's a tab on HW's website: "Common Problems" and identifies the situation where the headunit powers up but the handlebar controls don't work. I tried to copy that portion and here's the link:
http://hawg-wired.com/tech_faq.php
If this isn't the correct link, go to HW's website and you'll find it.
Good luck.
Carl
Old Mar 6, 2010 | 04:34 PM
Harleypingman
After the above post, I checked the link and it isn't the "common problems" link, but you will see the tab "Common Problems." Click on it and you'll find the one describing HSA not working (radio works but handlebar controls don't).
Good luck.
Carl
Old Mar 6, 2010 | 08:24 PM
Mike5959's Avatar
Mike5959
well, didnt have a chance to take the fairing off today. I will have to look at it later. It was working fine for months.
restorick
Audio Systems
Mar 27, 2016 07:31 PM
jester0618
Audio Systems
Nov 16, 2015 04:38 PM
Roadie13
Audio Systems
Jul 4, 2015 02:04 PM
wrenchguy24
Jun 6, 2014 02:32 PM
CruzN
Nov 7, 2008 01:36 PM
