Pushrod/Cam Question
Old Mar 25, 2010 | 05:18 AM
1sweetglide08's Avatar
1sweetglide08
Default Pushrod/Cam Question
I'm getting ready to have a SE 255 cam installed with adjustable pushrods..I have a chance to buy a used set of SE 103 jugs and pistons. My question is what else will I need to buy, do I still did the adjustable pushrods or should I use my old pushrods and how much more labor is involed than a cam only job? If I get the 103 and cam done how many labor hours would the dealer charge? I won't need any dyno time...I have a PC-V with map from Jamie at FuelMoto.
Old Mar 25, 2010 | 06:33 AM
troop's Avatar
troop
PM sent
Old Mar 25, 2010 | 06:39 AM
imrotton2's Avatar
imrotton2
if you are going to the 103,, i would say ,have some headwork done... higher lift on cams need adjustable rods....those pipes will be what kills the build... a good dyno tune can be very impressive ,over a canned map
Old Mar 25, 2010 | 06:55 AM
VETERAN75's Avatar
VETERAN75
The gaskets for the upper rocker cover, and orings for pushrod tubes, and breather filter, oring , gasket set for the breather in the rocker cover are way less than the adjustable pushrod kit is. You can use your oem pushrods that way. If you are going to do bigger things later maybe you should go ahead and get the adjustables. Or go ahead and save a little money and do the 103 now. Do a search and find one of the cam jobs in detail here and I think if you have some tool you can do the cams yourself, probably the whole 103. With a service manual.
Old Mar 25, 2010 | 02:04 PM
roaddawg65's Avatar
roaddawg65
3rd Gear
My question would be who is selling the jugs and why. I would check to see what it would cost you to have your stock jugs bored to match a set of pistons rather than buy someone else's cast offs.
Old Mar 25, 2010 | 02:38 PM
Road Ranger's Avatar
Road Ranger
I tend to agree...I would bore my own out or buy new before I would ever buy a used set. I'm not sure what the cam job is costing you but you should be able to go big bore between $750 - $1000 installed.
Old Mar 25, 2010 | 03:27 PM
djl's Avatar
djl
+1 for boring your cylinders to fit a new set of pistons.
IIRC, dealers in my area allow 8 hours to R/R the top end and R/R cams; the rate is $75/hour.
You can save some $$ and do the job yourself; just takes a service manual, some basic hand tools, a place to work, motivation and a service manual.
Old Mar 25, 2010 | 03:35 PM
1sweetglide08
Good advice so far...leaning towards buying new jugs and pistons or to have mines bored. Thanks ...
RUBI-VET
Jul 21, 2016 09:32 AM
Harleyvetteguy
Feb 8, 2015 08:03 PM
BJFLHT
Apr 10, 2012 07:36 AM
1sweetglide08
Jan 10, 2010 11:13 PM
masterblaster
Dec 5, 2007 11:41 AM
