e-Bay Wild pigs
Old Aug 28, 2006 | 01:21 AM
Dogs of war's Avatar
Dogs of war
Default e-Bay Wild pigs
The guy on e-bay has wild pigs for $185 or you can make an offer on them.
I have 2 questions.
1. Will I need to take my bike to the dealer for a remap of a stock 06 SG if I put these on?
2. What is the lowest price you have heard of this guy taking for these?
Old Aug 28, 2006 | 02:34 AM
dawg's Avatar
dawg
Default RE: e-Bay Wild pigs
Just slip ons shouldn't need a remap
Old Aug 28, 2006 | 03:14 AM
ApeKing's Avatar
ApeKing
I paid 145 for mine from the same guy Im guessing. I had to have a high flow air cleaner and rejetted carb so I would imagine just slip ons or not youll need a re-map. Once you get them take the baffles out and unwrap the fiberglass packing and throw it away for a deeper rumble.
Old Aug 28, 2006 | 09:57 AM
bucs012's Avatar
bucs012
I may be wrong, but why would a bike need a re-map by just changing "mufflers only?" The air/fuel mixture has already gone through the engine and burned. The air/fuel is just exiting through the mufflers. Think about how many cars get mufflers changed and never need to change air/fuel mix. NOw if you change the air breather and or exhaust sytem up at the engine I can see.
Can someone explain this?
Old Aug 28, 2006 | 11:07 AM
Dogs of war
ORIGINAL: bucs012
Good question.
Old Aug 28, 2006 | 01:06 PM
ApeKing's Avatar
ApeKing
Diferent back pressure.
Old Aug 28, 2006 | 01:40 PM
Dogs of war
Just got off the phone w/ the stealer, they said I will need a power commander or a race tuner. It will run to lean w/o one. If I put them(Pigs) on, how will I know if it is running too lean? Pull the plugs?
Old Aug 28, 2006 | 01:55 PM
gunrunner's Avatar
gunrunner
A plug check is a good idea, for any change, but if these come with baffles wraped, you may not need to remap, just check your plugs before and then after, a slight tan or grey color is what to look for, if it gets whiter after the mufflers are on then its running leaner, a bunch of these guys throw off on the dealer download, but Ive done two bikes now and had great results both times, a PCIII and sert are overkill if just changing to slipons and a air cleaner, and you will save a few hunddred bucks too.
Old Aug 30, 2006 | 11:52 PM
walkerjo's Avatar
walkerjo
5th Gear
I put Wild Pigs on my 05 a year ago and didnt have to do anything, and for the cost compared to 400-600 for the other brands I think they sound great. I was told as long as I didnt change anything else, there was no need for a remap
Old Aug 31, 2006 | 12:09 AM
KRUZER's Avatar
KRUZER
Stage II
I have personally installed over a dozen sets on bone stock bikes with no ill effects wgat so ever. I installed them on my 87 EG Classic, my 98 Ultra Classic, my 2004 Ultra Classic, and 2 weeks ago on my 07 Road Glide. The 07 ran fine. I have since installed the SE air cleaner and SE Race Tuner just because I wanted to. I put a set on my buddies 05 EG Classic 4 or 5 weeks ago with no ill effects what so ever. My neighbor has them on his carbed 99 Road King also.
Dale Goodwin
07 Road Glide
SE Air Cleaner
SERT
Wild Pig Pipes
www.kruzerproducts.com
billyballs279
Jul 7, 2022 09:53 AM
MikeSz
Oct 26, 2010 07:28 AM
Roger Williams
Mar 17, 2010 01:07 AM
Dalejo
Oct 10, 2008 09:06 AM
VenturaChop
May 25, 2007 03:13 AM
