Pulling Codes on a 09 FLH???
Old Jul 30, 2010 | 10:19 AM
TexasBowhunter's Avatar
TexasBowhunter
Default Pulling Codes on a 09 FLH???
I don't think I missed it and I did a search and found nothing that would help on a 09 but what is the procedure for pulling codes on a 09 FLHX
Also while were on the subject is there a list of the codes that I can reference to to know what they are...
Thanks
paul
Old Jul 30, 2010 | 10:48 AM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Here ya go: www.fuelmotousa.com/harleycodes.htm
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Aug 1, 2010 | 11:00 AM
TexasBowhunter
Jamie,
Thanks fro the info...However...
Not sure what is happening with what I got and what your set of instructions wanted me to do but I didn't get the same results...
I got the PSSPEb (not the PSSPT) which wasn't supposed to come up according to the info...
by the way the E isn't really an E as it doesn't have the top slash mark on it...
However I got on the b...c1095 and c1216...These were not in the codes for referencing what was going on...
So after jotting them down I did clear the codes and will see if they come back...
By the way I have security and ABS...Not sure if this is the reason for the additional letters and the codes which didn't show up in the code ID you provided...
Thanks again...
Old Aug 1, 2010 | 11:41 PM
kingkingking's Avatar
kingkingking
P S SP t b
P - ECM Codes
S - TSSM (turn signal/security module), HFSM (hands free security module).
SP - Speedo
t - Tacho
b - ABS.
The PDF attached is for 08s. I have the 09 electrical service manual, if you have codes that arent in this PDF then PM me and I will look them up for you.
File Type: pdf
Old Aug 2, 2010 | 12:04 AM
Bluehighways's Avatar
Bluehighways
Here is a list of all OBDII Diagnostic Trouble Codes. Harley-Davidson does not use all of them but all of the Codes that Harley-Davidson uses are listed here.
The file is an Excel file. Use the Edit/Find Command to locate the Diagnostic Trouble Code number you've got.
OBDII Codes are the same for all manufacturers per the Clean Air Act
OBDII is On Board Diagnostics used since 1994-1996.
Old Aug 2, 2010 | 12:10 AM
Bluehighways
Oh, one more thing. H-D sells an OBDII DTSC Code Reader P/N 32312-10 List is $149.95 but they can be had for ~$120.00 On-Line. The Code Reader: Reads Codes, Displays the code definition, and will Erase DTSC's.
Old Aug 2, 2010 | 05:12 AM
kingkingking
Your speedo can do all of these things. So can the SEPST.
Old Aug 2, 2010 | 09:01 AM
TexasBowhunter
Thanks Guys
I believe I found the info I was seeking...dawg came thru again for me with a copy of the 08 manual which had the codes I was looking for...It did have to do with the abs as to either the front or rear brake was open...
Cleared the codes and we will see it it comes back...This was probably the reason the cruise wouldn't engage a couple weeks ago...I think I had a stuck rear brake pedal which wasn't opening the circuit to the brake for the cruise to engage...
Thanks for all the info
paul
PistonPuller
Jun 28, 2010 11:03 AM
103Eagle
Jun 11, 2009 09:57 PM
coyotedustr
Jun 6, 2009 08:35 PM
Lawdawg
Mar 17, 2009 11:27 AM
Thornhammer
Feb 28, 2009 08:36 PM
