Se 120r complete engine?
Old Nov 23, 2010 | 12:40 PM
  #331
lkr0's Avatar
lkr0
I was waiting for somebody to do this -- let us know how it turns out --very interested--thinking about putting one in my 09 RG (HQs 107) but I'm a torque hoe -- I want it down low where I can pull the front wheel off the ground--
Originally Posted by Eric in chicago
Going to color outside the lines a little bit with my 120r... Putting in Tman 662 cams, having a little headwork done and a good tune. wont be done for a month or so, will post up dyno sheet when done. Going to be a wild ride for sure!!
Old Nov 23, 2010 | 06:59 PM
  #332
itsaw0rkinpr0gre$$'s Avatar
itsaw0rkinpr0gre$$
"Seeker of Freedom"
First sheet is SAE, Second is Standard. Just noticed my scanner cut the tops off. I'll try to get a better scan soon.
Old Nov 23, 2010 | 07:44 PM
  #333
RGriff69's Avatar
RGriff69
Awesome numbers!!
Did you go with different heads or anything or just the straight crate motor?
Old Nov 23, 2010 | 08:01 PM
  #334
itsaw0rkinpr0gre$$
"Seeker of Freedom"
Originally Posted by RGriff69
Awesome numbers!!
SE120R Kit versus Crate, added SE roller rockers and timken bearings. built by Bluesprings Harley-Davidson of Bluesprings Missouri
Cost is very close to the crate,but you know who's building it and you get to make any modifcations you want along the way. I did very little modification from the stock kit as you can see, because the guys at Bluesprings HD were confident they could produce solid numbers reliably with the base kit. They pulled through and I believe there is more hidden HP on the top end if I allowed them more time with the bike.
This engine is exactly what I feel the streetglide needed for a powerplant. It has smooth responsive power curve with effortless acceleration. I can not stress enough it's fast for a 900lb touring bike.
Old Nov 23, 2010 | 08:57 PM
  #335
Biggzed's Avatar
Biggzed
Congrats man. That thing rips.
Zach
Old Nov 24, 2010 | 04:35 AM
  #336
hardwork2's Avatar
hardwork2
. The way guys complain about their motors being hot the monster notor will be a fire breather.
However, I bet it runs like a scalded dog though.
Old Nov 24, 2010 | 07:28 AM
  #337
lkr0's Avatar
lkr0
Impressive --
Old Nov 24, 2010 | 07:51 AM
  #338
red devil's Avatar
red devil
Damn they are impressive #'s! Seems like HD has a hit with this 120.
Old Nov 24, 2010 | 12:16 PM
  #339
itsaw0rkinpr0gre$$
"Seeker of Freedom"
I added the SE Premium Oil Cooler and it seems to run quite a bit cooler than my stock 96". summer riding will let me know. I plan to do a review after a 10 day ride around memorial day 2011.
Old Nov 24, 2010 | 12:32 PM
  #340
nickeenoo's Avatar
nickeenoo
Did you weld, balance, and true the crank? How smooth is this build compared to the stock motor?
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
