Air ride installed...
Old Jul 14, 2012 | 06:33 PM
  #681
coolerman69's Avatar
coolerman69
Originally Posted by Sloverado
When wiring up to the harley lock and unlock switch what color wires are you guys hooking up to? I have 3 wires going into plug. I am going to cut plug off and just wire them that way. I have 2 wires coming from relay just wanted to know what wires to use off switch? Thanks ahead of time.
Dont remember the color. Use your volt meter or test light. Hot wire to the center, one end to hot side of dump and the other to the hot side of compressor, or relay if your using one.
Old Jul 14, 2012 | 06:38 PM
  #682
Sloverado's Avatar
Sloverado
This is how im wiring it up.
Attached Thumbnails Air ride installed...-381819_2339040082141_1434085006_31891315_162887970_n.jpg
Old Jul 22, 2012 | 12:22 PM
  #683
rfd671's Avatar
rfd671
Stage II
anyone lower their front end as well? I was thinking about putting the progressive 2" kit in up front and was curious as to if anyone else had done this...especially with what you guys have been saying about having to air most of the way up towards the full extended shock...at 13-14 inches in the rear i didn't know what that would be like with lowering the front...thoughts? comments? suggestions?
Old Jul 23, 2012 | 06:53 AM
  #684
WOLFMAN94's Avatar
WOLFMAN94
mine is lowered 1 1/2".
Old Jul 27, 2012 | 04:24 PM
  #685
juststrokeit383's Avatar
juststrokeit383
Very informative!
If you guys are having the problems with bottoming/topping out riding solo/two up what about riding two up with a loaded tour pak and trailer behind...?
My 07 SG rides rough already, so some sort of change is needed. And I love the slammed bagger look! I am definitely adding this mod to my list hoping I get the smooth ride others are getting.
Old Jul 27, 2012 | 05:37 PM
  #686
coolerman69
Rides even better loaded. Remember these are car shocks
Old Jul 27, 2012 | 06:05 PM
  #687
juststrokeit383
Okay but when I air it up when Im fully loaded and then get off at stops isnt the bike going to top out and hit the muffler?
Old Jul 27, 2012 | 06:23 PM
  #688
coolerman69
Thats a possibility! But who is gonna know but you? I dump mine everytime i get off so it isnt an issue
Old Jul 27, 2012 | 06:54 PM
  #689
juststrokeit383
Okay well I guess there is only one more thing to do...
Order..
Thanks
Old Jul 27, 2012 | 08:35 PM
  #690
DuraGlide's Avatar
DuraGlide
Most of the guys having "issues" are on the 09-up frame. Seems like the set-up works best on the 08 back bikes. As coolerman said the bigger the load the better the system works. Got over 20k on my setup and still love it.
