Air ride installed...
Old Jul 28, 2012 | 10:52 AM
  #691
juststrokeit383's Avatar
juststrokeit383
The more weight the better it works for a smooth ride...? correct?
What you guys think would happen if I used 3/8" line? (I can get every fitting and hose from work) Just wondering tho...
In theory, it would be like blowing through a shake straw vs a normal straw, the hose would be more open for faster ups and downs...?
Old Jul 28, 2012 | 04:45 PM
  #692
DuraGlide's Avatar
DuraGlide
Unless you have a hotrod compressor you are just adding more volume to have to fill by running bigger lines. I'm running 1/4 line off the compressor to 2 1/8 lines to the shocks. Dumps in 2 sec and tops out in 7-8 sec. Fast enough for me.
Old Sep 20, 2012 | 09:48 AM
  #693
captgaryr's Avatar
captgaryr
1st Gear
Default Arnott Air Suspensions
They work great.....get the Aldans not the Bilsteins for a softer ride. The best price I found was at realbikergear.com
Old Sep 20, 2012 | 09:14 PM
  #694
Rick1981's Avatar
Rick1981
Originally Posted by 07standard
finally got my bag unlock/lock switch yesterday, went to work today to get electrical connectors out of my work truck, but forgot to grab wire to wire it all up lol... now I have to drive another 30 miles to my truck and back to get it so I can finish it up tonight and hopefully take a short ride tomorrow...
Nice work perk...
I will let you know when I do mine here in a couple months.
Old Sep 20, 2012 | 09:26 PM
  #695
Str33tgl1de's Avatar
Str33tgl1de
Originally Posted by DuraGlide
Most of the guys having "issues" are on the 09-up frame. Seems like the set-up works best on the 08 back bikes. As coolerman said the bigger the load the better the system works. Got over 20k on my setup and still love it.
So this won't work on my '12 SG? I thought a few guys said its not much of a difference between them.
Old Sep 21, 2012 | 07:07 AM
  #696
coolerman69's Avatar
coolerman69
Just did a "12 SG which had a lowering kit already installed. I left the kit on and used the first hole. It was ON THE GROUND! Looked awesome! It had a really low profile tire which kept it from rubbing when aired down.
Old Sep 21, 2012 | 07:12 AM
  #697
coolerman69
Your theory is flawed. If you had unlimited pressure on the end of that straw you would be correct. Trust me. I've done over a dozen of these systems, stick with the 1/8 tube that comes with the shocks.
Old Sep 21, 2012 | 09:19 AM
  #698
HTNHARD's Avatar
HTNHARD
The 1/4" line works just as good. Seriously. I used it for everything. It was easier for me to find 1/4" fittings for the setup. Could only find 1/8" fittings at my local ACE Hardware, where 1/4" were everywhere. Or just sit home and order from airridefittings.com
Old Sep 21, 2012 | 12:33 PM
  #699
coolerman69
1/4 works but it takes twice as long to fill an empty 1/4 line as it does a 1/8. The 1/4 dumps too quick and is harder to adjust on the fly.
Old Sep 23, 2012 | 11:04 PM
  #700
twistedcherokee's Avatar
twistedcherokee
Anyone know what size of air line comes on the Harley Ultra stock? I think the air shocks both Monroe & Gabriels use the 1/8" but the Harley ones are just a tad bit bigger. I thought they were the same size & thought I have been looking for the tee that I already have. Went out to the bike to check it out & the air shock line was too small. Back to plan A.
Toby
