Where do I get the fittings? What sizes/styles do I need? I think Home Depot has some of that stuff.. I'm trying to get as much of the parts before I start.
Fitting sizes I used were 1/4in and 1/8in. Not sure about Home Depot. I have a rubber and gasket store down the street from me that has fittings and hoses too. I used all push lock line and fittings. Easier to take apart if I have to change something.
I got all my brass fittings at ACE hardware. They dont have a brass 4way so i took a 3way, drilled a hole in the one blank side and soldered in a 1/8in fitting. If soldering is not your thing there are probably brass 4ways out there.
To everyone doing this mod I would suggest adding a small LED somewhere on the dash that lights up when the compressor. I had a switch that stuck and the compressor ran for about 15 miles and i didn't know it. If it had been a 150 mile run it wouldnt have been too healthy for the compressor.
Coolerman, sounds like a great idea.... Only problem is you guys keep coming up with more cool wiz, bang ideas I may never finish LOL!!!
Everything that can be done to make this work, or work better I'm all about.
You can buy small LEDs at any of the big box auto parts stores that have a 10-12" lead already on them. Wire it to the power out side of the relay or the up side of the switch and ground. Drill a 1/8 hole in the faring and epoxy it in
You can get LED holders from radio shack if you dont want to mess with epoxy.
