Air ride installed...
Old Oct 1, 2012 | 07:53 PM
  #711
slammed05fatty's Avatar
slammed05fatty
Originally Posted by clarkchriston
Air ride took a dump a few weeks back and I finally got around to finding out what went wrong.
The seal that connects the motor to the tank is cracked and leaking, it's not any of the fittings.
Since I have abs I had it mounted under the battery box which I do not recommend and will not do again. I think what happened is that the compressor was tucked in so tight that over time the impact from road bumps and bottom of the battery box caused too much stress on the compressor. I think I may just purchase the compressor set-up from Aarnot that mounts under the frame. I still love the air ride and think this is an awsome set-up.
where does arnott locate theirs exactly
Old Oct 2, 2012 | 07:31 PM
  #712
Elev8trman's Avatar
Elev8trman
Has anyone addressed the fact the kickstand stands the bike up straight
When lowered all the way down?
Old Oct 3, 2012 | 12:01 AM
  #713
DuraGlide's Avatar
DuraGlide
Black bike on the left is lowered all the way with this system. Ultra on the right is stock. I don't see where the bike is "straight up". I guess if the front is lowered drastically then it could be an issue. Couple of companies make wedges for the kickstand mount for lowered bikes to change the angle of the stand.
Old Oct 3, 2012 | 11:28 AM
  #714
clarkchriston's Avatar
clarkchriston
Sorry it's not Arnott but Legend Air suspension kit is what I will be switching to. I'll try to uplaod a picture
Old Oct 4, 2012 | 06:23 AM
  #715
WOLFMAN94's Avatar
WOLFMAN94
Elev8trman, I had the same issue because my front end is lowered 1.5".
I just removed the two bottom bolts on the mount plate and put a couple washers betweenthe plate and the frame, it just kicks the plate out about 1/4" and gives you the lean angle your looking for.
Old Nov 2, 2012 | 11:20 PM
  #716
juststrokeit383's Avatar
juststrokeit383
This winter when I put the bike on the lift for this mod I just might try to make a bracket like arnotts' bracket to mount my compressor under like Clark has shown and let ya'll know... If your interested that is..
Old Dec 8, 2012 | 07:13 PM
  #717
josh1's Avatar
josh1
So I just bought the Monroes 785 and viair 92c.
My question is I have two of the ACC. switches laying around, will 1 ACC. switch power the air pushing up, then pushing down dump the air? Or do I need to use both switches.
Old Dec 8, 2012 | 11:16 PM
  #718
coolerman69's Avatar
coolerman69
Neither, You need this
Old Dec 9, 2012 | 07:23 PM
  #719
josh1's Avatar
josh1
Anyone have photos of compressor mounted on 09 later street glide, I want to stay away for the fairing. Already have amp and tweeters in there and looks clean. Dont mind making a bracket if need be, just need to see where and how!
Thanks and Happy Holidays to all...
Old Dec 9, 2012 | 09:38 PM
  #720
coolerman69
I did Traceman's and mounted it just above the starter. Ypud never know it was there
