Super Easy Shift Linkage Mod
Old Jun 24, 2015 | 07:27 PM
  #51
skratch's Avatar
skratch
Originally Posted by designwebs
Update on the fix. The heim joints would not work on the standard shift rod. I even got another standard shift rod and it did not work as well. I paid 11.00 each for the heim joints at grainger. I think I am going to take them back and just order a shifter linkage from Landmark or Kuryakyn.
did you get the right thread for the heim joints? they should be 5/16 x 24 rh (right handed) thread. if this is what you got, there's no reason for it not to work. i even checked on the 2014 oem fiche and the shifter rod is the same one that's been in use since 1999.
what didn't work?
Old Jun 24, 2015 | 10:11 PM
  #52
designwebs's Avatar
designwebs
I double checked the grainger part number and specs against the one that harfooz gave me the link too and everything is the same. Wonder what gives?
Old Jun 24, 2015 | 10:25 PM
  #53
designwebs's Avatar
designwebs
I think I found the problem. After looking at the part spec's on the grainger website it turns out these are left hand threaded..... WOW, I can't believe I missed that.
Old Jun 24, 2015 | 11:02 PM
  #54
GriffinDenim13FLHX's Avatar
GriffinDenim13FLHX
Easy fix man. It's a good thing that's all it was.
skratch called it on his last post .
Old Jun 24, 2015 | 11:04 PM
  #55
Bikerscum's Avatar
Bikerscum
Old Jun 25, 2015 | 04:36 PM
  #56
davidwruth's Avatar
davidwruth
eBay had them for 2.95
Old Jun 26, 2015 | 05:26 PM
  #57
nervous's Avatar
nervous
Originally Posted by GriffinDenim13FLHX
Mine are completed and was an easy mod to do. Much firmer shift (feels like). As well a piece of mind that the linkage will not fall off in the middle of nowhere. Which in Idaho , middle of nowhere is easy to do here. Took about 10 minutes to do. Did not have to do any adjusting, or moving the teeth on the splines. Perfect size HEIM joints worked great. Purchased my set through: http://www.ebay.com/itm/391165355207...%3AMEBIDX%3AIT Trusted seller, 100% feedback, nice product.
I see this kit comes with two 1 1/4" bolts, but the OP used one 3/4" and one 1". What have other folks used.
Thinking on finding some Allen head or button head bolts this weekend in preparation for the ends here next week.
http://pages.ebay.com/link/?nav=item...obalID=EBAY-US
And not bad looking pieces either. Got here very fast.
Attached Thumbnails Super Easy Shift Linkage Mod-image-1513191472.jpg   Super Easy Shift Linkage Mod-image-2112977597.jpg
Old Jun 26, 2015 | 06:02 PM
  #58
splattttttt's Avatar
splattttttt
I used 1" on both ends, works. But I'll be revising it eventually for a more unique look.
Probably naval brass.
Old Jun 27, 2015 | 11:53 AM
  #59
Crashone's Avatar
Crashone
I found this right on time, I have been noticing how sloppy my linkage seemed to be getting and come across this fix. I finally found the parts locally at an Ace Hardware store of all places. One thing I did find was that the transmission lever was a #8x1.00 fine metric thread. I had to run back out and pick that one up.
Also Ace happened to have brass acorn nuts so I now have a brass nut.
Old Jun 27, 2015 | 01:28 PM
  #60
davidwruth's Avatar
davidwruth
Done. All for less than 8.00. Not bad. Great mod thanks.
