Progressive Drop In Kit
Old Feb 26, 2011 | 09:14 PM
zombieroadking's Avatar
zombieroadking
Default Progressive Drop In Kit
Ok, so here's the deal. My progressive drop in fork kit came in the mail for my 2009 road king classic the other day. I'm kind of new to working on bikes, but I'm an ASE automotive technician, so I'm not completely clueless and mechanically retarded. But as I was reading though the instructions, I found that there is a lot to be desired when it comes to putting all of this together. I was under the impression that i wouldn't have to remove my forks/wheel/fender.... and sure as **** the instructions say that i have to. SO, someone PLEASE guide me in the right direction!!!
Old Feb 26, 2011 | 10:43 PM
rg_dave's Avatar
rg_dave
You have to remove the foks. Remove the fork caps, oil and drop in the kit. Cut the spacer to fit the amount of lowering you need. I think the big thing is that you don't have to drill the dampening rods. On some bikes you just have to loosen the fork clamp to remove the fork cap, can't remember whether that is the case with the Roadking. On the fairing bikes you have to pull the forks.
Old Feb 27, 2011 | 08:41 AM
gilbos440rt's Avatar
gilbos440rt
Which Kit? part#
Old Feb 27, 2011 | 10:50 AM
onaride63's Avatar
onaride63
It's been a couple years since I put mine in but, I remember having to take my forks off and having to replace the dampaning rod spring. It's not hard. I didn't have a seal installer but found the extention tube on my shop vac worked great. Good luck
Old Feb 27, 2011 | 11:56 AM
bagman1's Avatar
bagman1
You didnt say if its a lowering kit or not, if it is like it was said you have to remove the forks and cut the spacer to set the preload, if its just a progressive spring you still have to drop the fender, and forks then just remove the cap and repace springs and spacers. On a bagger, fork work is a pain because you have to remove everything to get into it, on a non bagger you can just remove the caps and replace from there. Double master here too working on a third.
Old Feb 27, 2011 | 12:52 PM
Progressive Suspension's Avatar
Former Sponsor
Depending on the bike, the Drop In Kit can be installed with the forks still on the bike. Baggers and FL Softails utilize a bolt through top triple clamp (as opposed to a traditional clamping style). Because of this layout, the fork legs must be slid down to remove the top caps. Not a huge project, but certainly a bit more work than required on a Sporty or Dyna.
The legs do not need to be taken apart, though. Once the top of the fork is exposed and the cap removed (careful it is under tension) the stock spring is taken out and the new main spring, washer, compensation spring and a small prelaod spacer are inserted and the fork can be buttoned back up.
If you're still having trouble, give our tech guys a call and we'll walk you through it.
877.690.7411
Old Feb 28, 2011 | 09:40 AM
zombieroadking
Thanks guys, Im going to be tackling this project today, i will post pictures when im done.
Old Feb 28, 2011 | 10:58 PM
Bertk's Avatar
Bertk
I did mine a while back. The only thing I didn't do is remove the top caps and install the springs. I had my indy do that. Anyhow, here are some pics of the process.
Old Mar 1, 2011 | 04:32 AM
grbrown's Avatar
grbrown
When you are tackling jobs like this you really should have a service manual for your bike, to guide you through the process of getting to the things you want to change. You can't expect an after-market supplier to provide detailed instructions for every single model their parts fit!
bigpappa160
Oct 3, 2018 09:11 PM
Hades02
Mar 6, 2016 07:31 AM
Traxxtar
Jun 6, 2015 04:43 PM
SwiftyBKells
Dec 29, 2012 07:38 AM
London dude
Mar 27, 2009 11:13 PM
