exhaust leak
Old Apr 6, 2011 | 06:34 PM
ponch3640's Avatar
ponch3640
Default exhaust leak
What's the easiest way to know you have an exhaust leak. Just installed dresser duals and would like to know if i have a leak. Changed the gasketsand just want to make sure i didn't pinch them
Old Apr 6, 2011 | 06:42 PM
mgmmgm's Avatar
mgmmgm
what about using a lighter and see if the flame flickers around the unions and at the head pipe?
Old Apr 6, 2011 | 06:47 PM
TWIN CAM 96's Avatar
TWIN CAM 96
Let your bike cool off take some soapy water in a spray bottle and spray it around the pipe you will need a remote starter switch to crank over the engine or do the same thing by hold your hand up to the jug to see if you feel air blowing out.
Old Apr 6, 2011 | 06:55 PM
angelrod's Avatar
angelrod
when the engine is warm , give it some gas and let it go, if backfires you got some leak issue
Old Apr 6, 2011 | 07:35 PM
FDHOG's Avatar
FDHOG
Definitely wait till it's at normal temp. Mine will pop if I blip the throttle before it hits normal temps, after that she's pop free.
Old Apr 6, 2011 | 07:42 PM
Toypuller's Avatar
Toypuller
Use a cigarette.
Follow all the joints with the smoke.
Old Apr 6, 2011 | 10:03 PM
Phat09flhx's Avatar
Phat09flhx
Best way I have found to do a new header or reinstall from and old school bike tuner is to tighten snug, warm up the motor and let it cool and tighten again. Do this a few times and you'll never have leaks.
Old Apr 8, 2011 | 08:27 AM
ponch3640's Avatar
ponch3640
Thanks for all the help guys. No exhaust leak here!!!
Old Apr 8, 2011 | 03:44 PM
EastSideBikerTrash's Avatar
EastSideBikerTrash
Ponch,
I've had nothing but trouble with the stock gaskets. I always use the SE gaskets and double up if necessary. The stock gaskets have to be formed and tend to squeeze out.
Dave
peeweesenior
Aug 26, 2012 10:28 PM
GymChamp
Nov 26, 2009 02:56 PM
bucs012
May 27, 2008 09:16 AM
OldBoldPilot
Exhaust System Topics
Feb 20, 2007 07:14 PM
Ultra LR
Aug 15, 2006 10:59 AM
