Do I really need to remove the fuel tank?
Old Apr 30, 2011 | 05:54 AM
king1065's Avatar
king1065
Default Do I really need to remove the fuel tank?
I was reading the instructions to install the HD Premium air horn kit 69423-05. The instructions say to remove the tank to run the horn harness as needed. Has anyone done this install without removing tank?
Thanks
Old Apr 30, 2011 | 06:09 AM
robfaulkner's Avatar
robfaulkner
Default Remove gas tank???
What your and model is your bike? On my 07 FLHTP I can lift the tank enough to fish wires under it. Other years may be different. Remove the front and rear bolts, slide a piece of wood under it to hold it up, and install the new wires. I often use a long thick zip-tie to push through, with the new wires taped to the zip-tie.
Old Apr 30, 2011 | 06:50 AM
sporacer's Avatar
sporacer
Thanks
You can have the tank off in less than 2 minutes.
Old Apr 30, 2011 | 07:09 AM
ehans's Avatar
ehans
I just did the same thing when installing a Powerlet PowerBar Plus outlet, except instead of a piece of wood I used my wife. Lifted it up high enough and she snaked the wires back to the battery.
Old Apr 30, 2011 | 07:22 AM
king1065's Avatar
king1065
I have a 2011 Ultra Limited. I was thinking about using the long thick zip-tie method.
Thanks
Old Apr 30, 2011 | 07:25 AM
king1065's Avatar
king1065
I looked at the manual and saw the procedure. It doesn't look like too big a deal but I was looking for an easier way out.
Thank you
Old Apr 30, 2011 | 07:48 AM
FLHTCU Owner's Avatar
FLHTCU Owner
Thanks
Don't be afraid to take the tank off. It's not that big of a deal. Get a quick disconnect (if you have the crossover line), and it's much easier to take it off in the future.
The one thing I don't like about fishing under the tank, is that the wire will sit between the tank and the wire conduit, but not in the conduit. It's just something I prefer doing, rather than fishing it.
Old Apr 30, 2011 | 02:41 PM
Navy Mustang's Avatar
Navy Mustang
Dude, you're overthinking it. The new H-D tanks come off very, very easily. Just make sure your fuel level is low so the tank is light. Two bolts in front of the seat, one bolt on either side of the front of the tank. Quick disconnect on the fuel line. Lift off and set it aside. You'll be happy you did it as it's so much easier to route your lines inside the wire harness on the frame. Do it right the first time.
Old Apr 30, 2011 | 03:36 PM
Coolhawg6622's Avatar
Coolhawg6622
Or less...........
skydweller97
Oct 15, 2014 06:57 PM
Cpitch
Mar 28, 2011 12:25 PM
rhaneski
Apr 6, 2009 06:54 PM
cornishman
Aug 6, 2007 05:26 PM
chilango13
Apr 28, 2006 05:06 PM
