Donnie Peterson did some articles a number of years ago on rear cylinder oil leaks on 103's and 110's. If I remember right the leaks were due to very high heat combined with the cylinder liner actually shifting causing the head gasket to leak. I don't know if that is the case on the 120, but no doubt heat plays a factor.
I think the 120R is not the best engine to put in a full fairing-ed touring bike that gets used in traffic. The engine is meant more for racing than for touring. But to each his own.
I believe if you do not have the crank welded and do even a little hot-******* you will have issues......Great motor for the price but still needs some massaging to be reliable and make max power. Time will tell.
Everyone keeps saying that you have to do more to them than install as out of the crate but so far mine is still a very happy hot rod. I am not very nice to it and it just keeps running like a clock.
Awesome! How many miles on it? Can you post a dyno sheet? I think the 120R is a great value!
Not the case since I do more than a little more than hot *******. But then again I am not at max horse power which can be in the 180hp zone.
Been there, done that on my 05. On my first 98" build the wheels shifted. What made matters worse was I was running geared cams. Pretty much destroyed the entire motor. I had Dark Horse true and plug my next crank, install Timken bearings and it ran gears for the last 4 years as quiet or quieter than chains.
I'm now in the middle of building a 120r from the bottom end up. The Timken cases have been sent out for boring for the larger cylinders and the crank is being plugged/welded/trued. After my first experience I'll never trust a stock crank again.
Rick
[IMG][/IMG]
My 95" started to run a little rough before I built this new engine. I did not get to measure the run-out when it was torn down but I know my wheels were slipping. NEVER run a high performance engine of any size without welding the crank!! It made 101/108.
I travel a lot in the summer working as an official for NHRA, so I only did 1500 miles on this bike last summer. I have the dyna and a bagger, the dyna is what I consider my ride for within 100 miles of the house. The bagger also gets the nod when my wife wants to go with since the dyna is a solo seat ride (and will always be so).
I did have to put a tire on the dyna mid season. The tire had less than 2000 miles on it when the 120R was installed and didn't last four months. I am not a put it against the post and burnout guy, just toasted the tire from hot rodding.
