Dynojet Power Vision
Old Oct 19, 2011 | 08:46 AM
brockjohnny's Avatar
brockjohnny
Default Dynojet Power Vision
I just ordered a PV and can't wait for it to get here. I have a 2010 Street Glide with a full D&D pipe and a Zipper's max flo air cleaner. I have been running it with no tuner per D&D. I am new to messing fuel electronically although have some experience with carburation. Can I run a log of the bike with the stock map to compare head temps, etc. before I put in the new map Fuel Moto is sending with the unit?
Old Oct 19, 2011 | 08:50 AM
dbell66253's Avatar
dbell66253
Subscribed, want to see how the PV works out for you.
Old Oct 19, 2011 | 08:58 AM
vtwinbmx's Avatar
vtwinbmx
Jamie will load a map that will be veryclose to perfect. I would use that map and tune from it
Old Oct 19, 2011 | 09:16 AM
XARAN's Avatar
XARAN
The first time you connect the PV to your bike it will lock to you ECM. So it can only be used on that ECM for tuning. I believe it can be used on other HDs as a code reader . When it does this it will also make a copy of the tune that is in the ECM and save it. This is the original tune and can be loaded into the PV software and compared, tweeked etc.
I think you will be happy with it, Ive had good luck with my PV from Fuel Moto. I had jamie tweek the original MAP 2 times to get it as close to perfect as I think it can be without a dyno run, and based on my riding style. Its really easy to use , only takes a few minutes to flash the ECM. Im going to play with some data loging in the next few weeks and see if I can tweek the current MAP any more.
Old Oct 19, 2011 | 09:19 AM
skratch's Avatar
skratch
yes, you can. when you first get it, you can do a backup of your stock map and save it to your computer. you can also have it loaded in one of your 6 slots and have it available for flashing. so you can datalog with your stock map loaded, and then reflash, and datalog again with your improved map.
Old Oct 19, 2011 | 09:25 AM
brockjohnny
What parameters are available to data log? Is head temperature one of them?
Old Oct 19, 2011 | 09:38 AM
Lone Rambler's Avatar
Lone Rambler
Jamie has some useful video clips of the use of the PV on the Fuel Moto site you should check out sometime.
Old Oct 19, 2011 | 11:26 AM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Yes you can easily datalog your current setup no problem and you have about 50+ channels to choose from including cyl head temp. When you install our calibration it should be very accurate and it is adaptive with the factory O2 sensors. If you choose to fine tune you can populate fuel and ignition corrections using the included Auto Tune Basic/PV Log tuner program. You are always welcome to contact us for support if needed, and here are the step by step instructions for using the Log Tuner program http://fuelmotousa.com/PVlogtuner.htm
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Oct 19, 2011 | 01:52 PM
rscott's Avatar
rscott
Smile
Totaly happy with my power vision First map sent byFuelMoto close so I contacted Jamie and he sent me a modified map and it's spot on.
As others have stated Jamie and folks at Fuelmoto top notch. You can't go wrong dealing with them.
Bob
Fatboy0192
Jun 24, 2019 04:13 PM
jhblaze1
Vance & Hines
16
Jul 1, 2018 12:40 PM
Celphish
Jul 19, 2015 05:49 PM
Rfc
Feb 11, 2013 06:07 PM
AdrianVall
Exhaust System Topics
Aug 29, 2008 12:02 PM
