Backrest relocation
Old Dec 3, 2011 | 07:36 AM
08ClassicRider's Avatar
08ClassicRider
Default Backrest relocation
Hey gang........I have a 2008 EG Classic and I just purchased a H/D Tallboy seat.....Now I am have a problem....on the stock seat I had a rider backrest ....H/D stk#52900-09A....... with the new seat pushing me back 2 inches I now have to relocate the mounting bracket that is attached to the rear fender to fully acquire the added 2 inches the seat will afford me.
I did not install that bracket or the backrest, it came with the bike(2nd hand)
My question .....Do I have to remove the rear tire to access the two bolts holding the backrest bracket or are they part of the rear fender and when I do remove the bracket will they remain in their respective positions?
If so does anyone know of a method to facilitate the relocation of the bracket without removing the rear tire.
I"m thinking of drilling the top of the bolts, taping them and them inserting a set screw of some sort so they will not fall out...Am I on the right track here?
Thanks for any positive feedback
Sleepy
Old Dec 3, 2011 | 07:57 AM
glide2005's Avatar
glide2005
No, you don't have to remove the rear tire. Simply remove the braket and move it back to the next set of location holes, or more if needed. The hold down bolts will not fall out with the nuts removed. Hope this helps.
Old Dec 3, 2011 | 08:10 AM
Texas Fat Boy's Avatar
Texas Fat Boy
What glide said, just unscrew the nuts, the bolts will not fall out or turn.
Unless you have the adjustable backrest then it won't move back.
Old Dec 3, 2011 | 08:15 AM
08ClassicRider
Thanks a million that is sure enough fantastic news..... I'll get 'er done this afternoon!
Waht a relief!
Thanks again for the info
Sleepy
Old Dec 3, 2011 | 10:53 AM
X Iron Butt's Avatar
X Iron Butt
Waht a relief!
Sleepy
08CR You can go here and get almost all of HD instructions on PDF. If this link doesn't work right click on this and open in new window. http://www.harley-davidson.com/gma/gma_product.jsp?PRODUCT%3C%3Eprd_id=84552444876837 3&default=none
goldie
Apr 28, 2018 07:39 AM
Master Gunny
Mar 19, 2012 02:36 PM
xdanman
Sep 19, 2010 05:11 PM
petemac
Oct 9, 2006 02:24 PM
petemac
Oct 9, 2006 02:23 PM
