First Oil Leak
Old May 14, 2016 | 11:27 PM
  #31
wscott's Avatar
wscott
FYI,the " RIGHT-STUFF " mfg'd by Permatex is a great alternative oil & heat resistant RTV type sealer too.
It's a much faster curing RTV type sealer thats specifically designed to seal oil & handle the heat generated in that area of an HD motor with no problems.
It's and is avail in black to match the HD's engine case too so you would hardly notice it.
Scott
Old Dec 4, 2018 | 01:43 AM
  #32
Bizio's Avatar
Bizio
Deleted. Sorry.
Old Jan 16, 2019 | 09:07 PM
  #33
newzealand's Avatar
newzealand
There is a semi easy fix that works pretty well.. You have to pull the stator, clean the plug and hole real good , then slip 2-4 drain plug O rings over the grommet. I like to use a light coat of high temp sillycone to slip the stator grommet back in place..
Seals em right up.. Got this idea from a friend who got it from a mechanic that works at Gail's HD in Missouri.
This is very effective. Thumbs up.
Old May 2, 2019 | 10:15 AM
  #34
natedawg58's Avatar
natedawg58
Stage I
Can I apply the sealer to the outside only or do I need to open it up and apply to the inside?
Old May 2, 2019 | 10:23 AM
  #35
cprhed's Avatar
cprhed
outside. you would have to disassemble the primary to get at it from the inside.
Not sure how others did it but there is almost no room to see or work so I used Qtips to get up in there to clean it.
Old May 17, 2020 | 09:03 AM
  #36
Mallard Slayer's Avatar
Mallard Slayer
old thread but one with some good information!!! just did this repair Friday and am happy to report no more leak!! my stator works just fine so why replace it when a can of carb cleaner and a tube of RVT will fix it
this forum has some priceless info on it from time to time!!
and this thread is worth reviving!!
Old May 17, 2020 | 09:30 AM
  #37
Budda109's Avatar
Budda109
Have same year bike. 2011 limited. Same fix. Started leaking at 20k. 3 years ago. Stator was fine but the leak drove me nuts. I used a forceps. Grapped the rubber, stretched it out. Cleaned with brake cleaner. Used the black RTV. Not a problem since. Last week I had my compensator upgraded. Had them throw a stator in while he was in there. It does work and it does last. At 45k now.But now I start over. Good luck
Durango Dave
Nov 11, 2021 10:21 AM
aussiesport
Jan 13, 2012 09:04 AM
mwriggs
May 3, 2010 09:49 PM
jfm5
Jul 9, 2009 03:50 PM
Square Dude
Oil Archive (no new posts)
Oct 26, 2005 12:28 AM
