leak at damn rubber stator plug.
Old May 10, 2012 | 03:01 PM
mtclassic's Avatar
mtclassic
Default leak at damn rubber stator plug.
well more of a seep but crap it is a 2011 with 17000 miles. My 04 with 80,000 miles never seeped there and I read that these plugs were supposed to be improved. Still under warranty till end of August but I am wondering how many 2011's have started seeping there as it was supposed to have a new and improved design on that plug for 2011.
Old May 10, 2012 | 03:07 PM
mkguitar's Avatar
mkguitar
warranty ?
go get it solved.
my 88,95 and 09 don't seep there. I guess I've been lucky.
Mike
Old May 10, 2012 | 04:14 PM
2black1s's Avatar
2black1s
I had the same leak. I didn't bother with the warranty because I hate anyone touching my bike. I repaired the leak with a little black RTV (silicone). There's a detailed description of my repair in the following link. https://www.hdforums.com/forum/touri...-oil-leak.html
Old May 10, 2012 | 05:54 PM
Punjabi Rider's Avatar
Punjabi Rider
Had that leak on my 07 UC service plan took care of it but it was a can of worms and turned out to be a loose stator magnet which damage the SE compensator, rotor and primary chain front sprocket, without ESP it would been very costly.
Old May 10, 2012 | 07:26 PM
TUCCI's Avatar
TUCCI
No leak on mine....sorry to hear yours is, that sucks.
Old May 10, 2012 | 07:44 PM
MBON's Avatar
MBON
I repaired my with black silicone. I went to a farm store and bought a big cattle syringe to get under the grommet, it worked like a charm.
Old May 10, 2012 | 09:28 PM
pdzani's Avatar
pdzani
+1 on the black RTV, mine was out of warranty fixed the leak fine.
Old May 10, 2012 | 09:56 PM
ddbuff's Avatar
ddbuff
4th Gear
Just had nine fixed under warranty, 2010 FLHX with 21,000 miles. Started with a seep and ended up a full blown leak with a small puddle on garage floor. One of my warranty claims.
Old May 11, 2012 | 06:50 AM
mtclassic's Avatar
mtclassic
how long did it take to go from a seep to a leak? I will most likely take it in before warranty is up in August just wondering what I have to look forward too. Being it is under warranty I will go the fix it route instead of the silicon route. So far the bike has not been back to the dealer since buying it. thanks Jeff
Old May 11, 2012 | 07:20 AM
Araba Shriner's Avatar
Araba Shriner
Yep Im with you on this one. Had same problem, only cost the $50 deductable. Dealer replaced without a hitch. Would have cost a ton without the ESP
