Bagger wobble exposed!
Impossible to diagnose on a thread. You might chase a lot of inputs and ideas and get nowhere. Question is, what changed from stock? Rear tire size, bag extensions, any thing else?. You could try removing the bags for a run to see if they are effecting the aero dynamica at speed. That is an easy quick check and free. If everything else stock then try it with stock tire. If that doesnt help then it needs a specialist to go through. Could be many things. Wheel alignment, neck bearings, engine mounts. List too long but a specialist go could through and check everything fairly quickly. Good luck and let us know how you get on. They dont do this in stock form when new so hard to suspect the shocks.
Look forward to hearing what you find!
I have commented in the past on the benefits of using stabilisers on our rubber mounts and this bike looks like an ideal candidate for some True-Track products, although it is worth seeking a solution before doing that.....
The alloy art brackets do seem far less robust, but if they do the job I can't see how that'll make a difference. And if, as previously stated, Eric Buell came up with the design, then all these vendors are just copying the concept if not the specifics.
I just ordered the alloy art product and will report back once I have a chance to really get out and ride and see if I can tell a difference, which unfortunately is likely to be several months out. If it doesn't seem to work for me I will attempt to hatchet job something together myself--not like any super precise engineering is required. I'm afraid opening a box with two brackets and a turnbuckle for which I paid $400 is likely to give me an acute case of buyers' remorse regardless of the result, but results may vary for the rest of you doctors and lawyers.
That said, I now have around 700 miles with Alloy Art brace and I believe it is a significant improvement. I've still felt slight wobble on occasion, but it seems much less noticeable and far less frequent than previously, and my gut reaction/seat of the pants comparison would be something on the order of a 70-80% reduction of the issue when it does occur, and probably an 80-90% reduction in frequency of occurrence--again, predicated on running new tires which may certainly have impacted results.
I will continue paying specific attention and report any further findings, but initial impression is very positive given the price--I don't know if the tru track entirely eliminates the problem, or is somewhat better or any better at all, but at this point I feel the $150 for Alloy Art brace was well spent.
YMMV, caveat emptor
http://www.youtube.com/watch?v=Gmw6QppXnEY
