Oil Pressure Light blinking
Old Aug 13, 2012 | 01:32 PM
ChipG60653's Avatar
ChipG60653
Stage II
Default Oil Pressure Light blinking
I have an 05 Road King Custom with about 72,000 miles. Recently the oil pressure light started acting funny: blinks or doesn't turn on when the ignition switch is turned on. Bike runs fine however, I don't want to cause any damage by the light not coming on to alert me to some serious issue. I'm thinking the oil pressure switch must be having problems. Should I change this switch or does anyone have recommendations on what else i should look at?
Thanks
Old Aug 13, 2012 | 05:38 PM
dawg's Avatar
dawg
Still got the stock cam tensioners? If so, have they been checked regularly starting at say 25k miles? Could be something simple like the switch, but could be more serious like the tensioners starting to go and plugging the holes, etc.
Old Aug 13, 2012 | 07:28 PM
hbsoldier3's Avatar
hbsoldier3
I had a piece of wire a foot back from the pressure switch rubbing on the frame causing a short and intermitent oil light flash. New wire installed no more problem
Old Aug 14, 2012 | 07:31 AM
ChipG60653's Avatar
ChipG60653
Stage II
I still have stock cam tensioners. I'll check for short in wire then cam tensioners. thanks
ukbertie
EVO
19
Dec 3, 2025 08:24 AM
Steel Steed
Nov 26, 2025 03:56 AM
Trav
Oct 2, 2017 06:30 PM
boazbird74fxe
Shovelhead
Aug 7, 2011 12:19 AM
tombeving
Exhaust System Topics
Nov 9, 2009 11:23 AM
