Auto speed volume not working
Old Oct 17, 2013 | 09:49 PM
tcar321's Avatar
tcar321
6th Gear
It is a common issue on all the 2014's. For some reason the AVC sucks on the new radios. I have tried every setting from avc off to max avc and am not happy with it at all. On my 07 ultra it worked much better. There have been a number of threads on this same complaint. I sure hope they get a fix to this in some future software updates, but I doubt they will.
Old Oct 19, 2013 | 04:25 PM
fevest's Avatar
fevest
I agree, it doesn't work very well. On my 09 ultra it worked fine. Seems to do nothing on my limited regardless of where it is set. Not the end of the world, will probably get fixed in a software update. I hope.
Old Oct 19, 2013 | 06:30 PM
UppercaseJC's Avatar
UppercaseJC
Originally Posted by GoGetter5832
Gotcha. I have done all of that. I just wish it had a volume setting for speed and one for "stand still" or similar. It would be great if when I was decreasing to a stop that I could set the volume to a very low level because I find myself always manually turning it down so I can talk to the people riding with me. Thanks for the replies!
The volume should adjust when you slow down or speed. I have a 2014 with the AVC and it is not working at all.
Old Oct 19, 2013 | 07:41 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
If you got the owners manual for the new bike, it has a section on the set up of the audio systems. I have the max bars on my setup and the volume control works quite well. Just have to practice with what you have and become proficient. It's not something you want to set while you are rolling. Good luck.
Old Oct 20, 2013 | 07:27 AM
fevest's Avatar
fevest
I know where that setup page is. It makes no difference which bar I have the avc set on. There is no change in the volume.
Old Oct 21, 2013 | 12:14 AM
Bigg Lou's Avatar
Bigg Lou
I have a '14 Street Glide Special and the AVC works great. Unfortunately does NOT turn off. Whether I have it on, or one of the 3 bars or full setting it is always activated and never turns off. There are many times I don't want it to lower the volume as I slow down but can't do that. Anyone else have this problem with their 6.5" infotainment center?
jpbutler1983
Aug 21, 2015 06:01 PM
olelucky
Jan 1, 2015 03:47 PM
pp6000v2
Mar 19, 2014 03:41 PM
jasle
Electrical/Lighting/Alarm
Jul 19, 2009 07:24 PM
thaasjr
Jul 4, 2009 06:12 AM
