push rod purchase
Old Mar 7, 2014 | 10:02 PM
dochawken's Avatar
dochawken
Default push rod purchase
Went with the Smith Bros. Easy install..allows me to keep the oem tubes. Plus I like that they appear more stout than the S&S quickees. Cam goes in next week! 57H
Old Mar 7, 2014 | 10:09 PM
RollieB's Avatar
RollieB
Nice.I went with the adjustables that Crane offers for the same reason.Not a ton of room to adjust them but manageable and very stout.Good luck with the cam swap!
Old Mar 8, 2014 | 12:26 AM
the warden's Avatar
the warden
Very good. I went with Fuelings adjustable push rods, which appear very similar to the Smith Brothers. They also use the stock tubes but I find them somewhat of a pain to install and adjust. The S&S quickies seem much easier to adjust and there is more room with the shorter tubes. I think I will try them next time around.
Old Mar 8, 2014 | 07:18 AM
Lowcountry Joe's Avatar
Lowcountry Joe
I went with the S&S quickies. The new tubes look nice and make it very easy to access the adjustment nuts....unlike pushrods using the stock covers. With the quickies, there is no need to remove the lifter blocks either. The quickies are robust and strong, so don't fret over assumptions. Been running mine for several thousand miles. Not a single issue and the 32 pitch thread allows for some precise adjustments and secure jam nut sets. Top quality construction for sure. But what else would S&S produce?
Old Mar 8, 2014 | 07:23 AM
hd_rolling's Avatar
hd_rolling
Fuel moto adjustable push rods was what I went with on my 96" and TW-555 cams, it also helped having there video right in front of my while installing that I could pause and start at any time even though I had seen it ten times before I started the install to make sure I had every thing I needed!
Old Mar 8, 2014 | 08:45 AM
Bodean46's Avatar
Bodean46
+1 on the FuelMoto.
Old Mar 8, 2014 | 09:35 AM
roadrunner10's Avatar
roadrunner10
FYI.... Smith Bros makes pushrods for Fueling as well as Fuel-Moto. AFAIK
Old Mar 8, 2014 | 04:33 PM
dochawken's Avatar
dochawken
I rather thought so...their tech support is superb...you get to talk to a person, not submit an email. Anyway, I am pleased with the product, very stout. Install pdf couldn't be any simpler.
Old Mar 8, 2014 | 04:38 PM
roadrunner10
I bought mine through Fuel-Moto for exactly the same reason.
galtjunk
EVO
29
Oct 1, 2016 04:07 PM
utterstan
EVO
Aug 7, 2013 06:33 PM
Bowedav
Exhaust System Topics
May 2, 2013 06:24 PM
JF7044
Sep 19, 2010 05:46 PM
0734
45
Sep 14, 2010 04:26 PM
