tunnel ? ?
Old Jun 27, 2014 | 12:50 PM
MidevilX68's Avatar
MidevilX68
Default tunnel ? ?
Traded in my fat bob for a 14 street glide ..I got rc components true duels and rc's 4 inch slip on's screaming eagle high flow air filter. Talked to the tech at the dealer and he said all I needed as far as turning is there 155.00 down load for a stage one ..? I have been told I need some sort of fuel management system like pcv . He took me back and fired up an ultra with the same set up and it sounded awsome he said it runs great . My ? Is do I need a tuner or will it be fine with there download I don't want to spend 155 bucks plus end up buying a tuner to boot
Old Jun 27, 2014 | 01:22 PM
mkguitar's Avatar
mkguitar
you can do one or the other, I wouldn;t suggest both
there are other tuning alternatives such as nightrider.com xieds.
but if your dealer is taking care of you, maybe go with that.
a more comprehensive tuner would make more sense if you anticipate further changes down the road such as cams, heads etc etc.
mike
SeaZund's Avatar
SeaZund
the dealer download for $155 is a one time hit to your pocketbook. If you invest that $$$ in a tuner, you'll be able to download as many different map changes as you want, as often as you want, whenever you want.
Old Jun 27, 2014 | 01:24 PM
prezflyr's Avatar
prezflyr
The question is, is it a proven download?
Old Jun 27, 2014 | 03:54 PM
Brykwil's Avatar
Brykwil
Dealer download is EPA restricted, a waste of money as far as I'm concerned.
Old Jun 27, 2014 | 04:15 PM
Keithhu's Avatar
Keithhu
Exactly. For roughly the same amount of money as the goofy download, you could get the Fuel Moto Microtuner, it takes PC-V maps which Fuel Moto will supply for as long as you own it.
http://www.fuelmotousa.com/fm-019.html
Old Jun 27, 2014 | 11:41 PM
MidevilX68's Avatar
MidevilX68
Thanks for the info I'm leaning more toward the power vision and save put my 155. 00 towards it.. I was really concerned with the heat rang and fuel economy as well as all out smooth throttle
mruth551
2014-2024 Touring Models
Jun 27, 2017 04:30 AM
T Man
Aug 30, 2016 08:53 AM
Toe Knee
Apr 5, 2015 11:10 AM
ric306
Jan 14, 2011 06:14 PM
firecapt11
May 9, 2007 01:28 AM
