Ordered H4 LED light $24
Old Jul 19, 2014 | 09:17 PM
c50plus's Avatar
c50plus
Default Ordered H4 LED light $24
My friend had an H4 incandescent bulb replaced with a high power Led light and he claims is much brighter. I found a Creed 80 W H4 replacement for $23 in Amazon. This is much cheaper than buying the whole Harley assembly ($500 for head light or close to that). I figure I have nothing to lose spending $24.
A regular incandescent H4 uses 55W/12 V= 4.5 amps low beam and 60W/12 V= 5 amps approximately ( I am assuming 12 V battery ). I know is a bit higher.
Now the 80W Led is not 80W/12v= 6.6 amps. It actually consumes 1 amp. So it must be 80W equivalent.
I will test and then report to you guys.
Here is the link. Anyone else has tried this?
Amazon Amazon
Old Jul 19, 2014 | 09:38 PM
smithbrl's Avatar
smithbrl
I'm VERY anxious to read your report. I have the HD LED headlight and it's a little creepy at night in sharp corners. Straight road it's great.
I would like to get some stray light from the top of the headlight so it would light up the corners a little. I wouldn't mind sacrificing a little intensity down the road. If the led bulb works, I can put my Hella headlight or my stock HD headlight back on.
Old Jul 19, 2014 | 10:55 PM
onecoolpilot's Avatar
onecoolpilot
I saw this somewhere about a week ago and I've been going back and forth on whether I should do it or not. The one I saw was on headwinds.com and is $99. Your's is a little different design, and 1/4 the price.
Please come back and let us know how it goes.
Old Jul 19, 2014 | 11:45 PM
bklynbob's Avatar
bklynbob
Headlight optics are a pretty exact science. The reflector is designed for a certain amount of light bulb length and diameter. Also the orientation of the filament( vertical,horizontal ) etc. Yeah, you'll probably get more light, but it will be scattered all over the place. Try it in fog or light rain and let me know how it works out.
Old Jul 29, 2014 | 07:52 PM
onecoolpilot
When is the new bulb supposed to be here C50?
Old Jul 29, 2014 | 08:11 PM
mwegryn's Avatar
mwegryn
I'd also be curious to hear how the light pattern is.
Old Jul 29, 2014 | 08:17 PM
Iceman24's Avatar
Iceman24
Interesting...if it works well then this bulb really blows other LED headlamps out of the water IRT pricing.
Old Jul 29, 2014 | 08:49 PM
c50plus's Avatar
c50plus
Update: I checked my Amazon order and they are in back order so I got to wait like three more weeks. I got a headlight lens form my previous ultra and I am going to put the LED bulb in there , apply 12 Volts and then put side by side with my 2012 limited incandescent headlight to compare. Of course only one will be on at a time. I will take pics and post. Hang in there. Good things are worth waiting for.
I understand that the optics may not help my Led bulb too much but hell if it is much better than the incandescent one then it is a good deal for $24. I love to experiment. BTW that is what I do for a living.
Old Jul 29, 2014 | 08:56 PM
Jerry L's Avatar
Jerry L
Keep the good info coming! Interested in this as well.
Old Jul 29, 2014 | 10:25 PM
SeaZund's Avatar
SeaZund
Originally Posted by c50plus
... I got a headlight lens from my previous ultra and I am going to put the LED bulb in there , apply 12 Volts and then put side by side with my 2012 limited incandescent headlight to compare. Of course only one will be on at a time.
run a 18 inch pigtail from the Ultra's cigarette lighter plug to the LED ; then you can have both powered on at the same time
