Advice on XM receiver location
Old Aug 24, 2014 | 08:07 PM
rattracer's Avatar
rattracer
Default Advice on XM receiver location
I put an XM satellite radio receiver on my SG this weekend. It works great, but I'm not real excited about the location. I simply unsnapped the left windshield bag and fastened the radio bracket there. As you can see in the linked picture, it leaves a little to be desired. So I'm wondering, who has a better idea? Thanks for any responses.
http://imgur.com/TS3RsaG
Old Aug 24, 2014 | 09:53 PM
12Bravo's Avatar
12Bravo
I am using a Kuryakyn fairing mount for my XM receiver
https://www.hdforums.com/forum/touri...l#post12936712
Old Aug 25, 2014 | 12:02 AM
mkguitar's Avatar
mkguitar
I had mine mounted on my left bar so I could change channels with my thumb.
this is the old Delphi unit which was made to slide into a car cradle, easily modified with 2 clamps on the bar
mike
Old Aug 25, 2014 | 09:17 AM
rattracer's Avatar
rattracer
Left bar would be ideal. As you can see, I've got my Garmin Nuvi mounted there. I may just put the XM there when I'm not using the Garmin. I am also looking in to a Garmin Zumo 665 that has XM - but I understand that it is only bluetooth compatible with XM, so I guess I still have to have the receiver somewhere. Be nice to have one unit do both, that would solve my situation. Thanks for the reply & pic!
Old Aug 25, 2014 | 03:13 PM
Hecklerboy's Avatar
Hecklerboy
Can you remove the center windshield bag and mount the radio there. It would balance things out better.
Old Aug 25, 2014 | 03:54 PM
mkguitar's Avatar
mkguitar
swap them
that puts the XM where you can thumb the controls
that also puts your gps where you can see it AND the road at the same time.
I don't like to put anything where i can't see the road at the same time.
deer, 2x4's, ladders, left turners...it can all happen fast
mike
Old Aug 25, 2014 | 04:07 PM
rattracer's Avatar
rattracer
mkguitar - That's not a bad idea. I went home at noon and took the Garmin off, put the XM on the handlebar, and put the windshield pouch back on. Much better. I don't use the Garmin around home, just on long trips. Just need to move the wires for the XM and it's done. maybe tonight if the temp gets down below 100 degrees!
Old Aug 25, 2014 | 04:08 PM
rattracer's Avatar
rattracer
Hecklerboy - Hate to do that, it's the only one of the three pouches big enough to hold anything more than a pack of gum...
Old Aug 28, 2014 | 03:53 PM
rattracer's Avatar
rattracer
Default Update on garmin and xm mount
Found this setup online:
http://www.tandtfabrications.com/sto...l_adapter.html
Ordered it today. Should be able to mount Garmin front & center, and keep the windshield bags. Think it's gonna work...
Old Aug 29, 2014 | 04:02 PM
slapshot12's Avatar
slapshot12
rat, I have the same XM unit. Mine is mounted on the right side, in front of your cup holder. I used the heavy duty plastic velcro (gator grip stuff) and ran the wires down the handle bar and into the fairing. I had the same issue with the HD mounted GPS on the left side. It fits right under the right side fairing pouch.
mervt198
Dec 14, 2011 05:07 AM
VINNIE JAMES
Jun 16, 2011 09:02 AM
fatguyona1000
Aug 22, 2009 01:07 PM
Texas Fat Boy
Feb 29, 2008 06:21 AM
HDSTORMDANCER
Jun 28, 2007 08:18 AM
