Reuse wheel bearings
Old Aug 2, 2023 | 01:06 PM
ronsnighttrain's Avatar
ronsnighttrain
5th Gear
Default Reuse wheel bearings
I bought an ultima king spoke wheel for my 06 night train. Stock size 21x2.15. I had the bearings swapped for the 3/4" axle. I had the steelership do the swap, plus install the new front rubber. When I picked up the wheel I was told the spacer between the bearings is a little short. I installed it, and now I have a very unnerving ting noise from the front wheel. After rechecking torque and make sure spokes were tight, I figured it is the spacer bouncing side to side inside the hub. My question is if I remove one of the bearings with the proper tool, could I reinstall it. The bearings dont even have 50 miles on them. I would hate to replace it .
Old Aug 2, 2023 | 01:26 PM
Goose_NC's Avatar
Goose_NC
My bearing tool removes the bearing by pulling on the inner bearing race. Exerting pressure on the ***** of the bearing. Insertion is done via pressure on the outer bearing race, so no pressure is on the *****.
I think you could damage the bearing upon removal. Is $20 worth the risk? A new bearing should last 20k+ easily.
Also sound like you need the proper spacer for that wheel.
Old Aug 2, 2023 | 01:30 PM
ronsnighttrain
5th Gear
That is why I want to pull the bearing.
Old Aug 2, 2023 | 06:00 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
The removal process cross loads the bearing, it should not be reused.
Old Aug 10, 2023 | 04:50 AM
Dano523's Avatar
Dano523
Lost here,since when shop did replaced the bearings for the 3/4" shaft, should have replaced the inner spacer with the correct needed length from the start (easy to make a new sleeve up on a lathe for the needed length from sleeve stock, or just starting with a longer oem sleeve and shorting it as needed instead).
So now with the axle nut tighten, already have the inner races being forced inward, the outer races as far as they will go in outwards now, bind wedging the ***** between the two races and trashing both on them out to start with.
So now, both bearings need to be pulled and thrown away, the new first bearing installed, measurement taken from its inner sleeve to where the other bearing inner race will sit when its installed, needed sleeve made to length and installed, then last new bearing installed.
Simply, the reason the inner sleeve in the first place, is to seat the inner races the same center line as the outer races installed in the rim sockets, so the ***** are riding center line of the races when the axle nut is tightened and pulling all that together via the outer shim spacers.
Also to point out,since the only way to get the bearings out now, is to press them out via the inner races (are pressed into rim using the outer sleeve surface so not to peen the other race via the *****), this will cause the ***** to peen the hell out of the race faces to destroy the bearing in the processes even more.
So not sure what dealership you had the bike worked on, but would be taking it back to have them replace the bearings and installing the correct needed inner length sleeve at their own cost.
Old Oct 12, 2023 | 07:45 PM
Screamin beagle's Avatar
Screamin beagle
You don't want any side load pressure on your *****.
Old Oct 12, 2023 | 08:03 PM
Buster's Avatar
Buster
ouch!
Old Oct 12, 2023 | 09:07 PM
dawg's Avatar
dawg
Does pocket pool count? Asking for a friend
Old Oct 12, 2023 | 09:13 PM
Buster's Avatar
Buster
Sorry about the derailment, I agree, ball bearings do not tolerate side loads well, replacing and proper spacer placement is the best solution.
bad tappets
General Topics/Tech Tips
15
Aug 26, 2020 06:14 PM
MNPGRider
Nov 30, 2011 03:46 PM
rodney123456
Apr 5, 2010 03:57 AM
bigdog1949
Wheels/Tires
Jan 18, 2010 11:40 AM
brazos95
Mar 27, 2007 06:23 PM
