2018+ Softail Models Breakout
The Everything Fat Bob Thread
Old Oct 12, 2020 | 09:31 AM
  #1031
Nomad1999's Avatar
Nomad1999
Default Air cleaner
Looking to replace the air cleaner on my 2020 FB. Have done the exhaust & tuner already. I'm liking the look of the S&S Stealth kit but not sure if it has as much airflow as the stock 114 kit....any input??
https://www.sscycle.com/products/ste...-hd-m8-models/
Old Oct 12, 2020 | 10:00 AM
  #1032
MoneyFor's Avatar
MoneyFor
The oem is al ready a highflow filter, I curious if you gain more power with an aftermarket one.
Old Oct 12, 2020 | 10:08 AM
  #1033
FatBob2018's Avatar
FatBob2018
The stock Ventilator air filter is good for at least 125 hp, with a Stage 1 you're going to be lucky to have about 85 hp, so there's pretty much no performance reason to change it out. I still have my original Ventilator even though I went Stage II long ago, it's plenty for that. Steve Cole showed a dyno chart from a Stage IV Fat Bob here about a year ago that was still using the stock Ventilator. I think the Ventilator would probably be able to handle even the 131" Stage 4 kit.
So the only reason to change it out would be because you prefer how some other a/c looks, or if you go to a monster build, like a 140 or 150 hp build.
Old Oct 12, 2020 | 10:42 AM
  #1034
Nomad1999's Avatar
Nomad1999
Not looking for more airflow...just want a different look.....was wanting to know if the s&s has at least as much flow.
Old Oct 12, 2020 | 10:50 AM
  #1035
Nomad1999's Avatar
Nomad1999
just looking for a different look. Like the old school look of the s&s i linked.....just want to be sure it has as much flow as the ventilator.
Old Oct 12, 2020 | 04:46 PM
  #1036
24v's Avatar
24v
Originally Posted by Wade Fargo
Shout out to Hairy Customs for the block off plates.
Thank you. That is the best pics of those I have seen so far, I appreciate the support. I am going to put these on my website, please let me know if you don't want them there.
Old Oct 12, 2020 | 06:09 PM
  #1037
Wade Fargo's Avatar
Wade Fargo
5th Gear
We’re good, thanks!
Old Oct 31, 2020 | 10:47 AM
  #1038
sugarjunkie's Avatar
sugarjunkie
6th Gear
Default Cruise control and smell of gas
Hi everyone. I have the 2020 fat bob. For anyone who has gotten cruise control by Harley, how many hours of labor was it? Also, after riding and parking in my garage I noticed the garage has a very heavy smell of gasoline. Have other people experienced that? Is this normal?
Thank you in advance for any help
Old Oct 31, 2020 | 11:23 AM
  #1039
Voxel's Avatar
Voxel
5th Gear
Hey sugarjunkie, others here have said they have done cruise control in less than an hour. For the gas smell, you should not be smelling gas unless you spilled some feeding the tank. You can expect engine smells but i have yet to notce gas except for when i had been at fault at the station filing up. 2019 fat bob owner here
Old Oct 31, 2020 | 11:38 AM
  #1040
sugarjunkie
6th Gear
Thank you for your response. Wow, less than an hour, that’s great. No gas was spilled so I’ll ask Harley about it, hopefully it’s something they are able to fix under the warranty. Thank you again
