2018+ Softail Models Breakout
The Everything Fat Bob Thread
Old Nov 8, 2022 | 07:08 AM
  #1431
murphc13's Avatar
murphc13
Default WILLIE G Baaaaby.....
Old Nov 9, 2022 | 09:43 AM
  #1432
murphc13's Avatar
murphc13
I can get it for sure though.Different Harley dealers in the UK have them.
Old Nov 9, 2022 | 09:45 AM
  #1433
murphc13's Avatar
murphc13
Default Derby Cover torque values?
The instructions say 3.9Nm but I've heard different elsewhere.I know it's gonna be very little.
Old Nov 10, 2022 | 04:11 PM
  #1434
murphc13's Avatar
murphc13
Originally Posted by Gar1414
Good idea. Here’s mine. No leakes. Very minor blow by.
are those Harley Davidson mirrors?Edge cut?How do you like them?
Old Nov 10, 2022 | 04:14 PM
  #1435
murphc13's Avatar
murphc13
Originally Posted by FLdynapilot
Almost done!
how are finding that mustang seat?
Old Nov 11, 2022 | 02:30 PM
  #1436
murphc13's Avatar
murphc13
Originally Posted by Igor Nabhan
Hey, guys,
Meet Beyonce.
Painted brake discs centers
sweet man.How did you get the ends of the big shots black?Are thry removable?
Old Nov 13, 2022 | 08:19 AM
  #1437
murphc13's Avatar
murphc13
Default Custom dynamics licence mount.
Does the fender need to be removed to install the supports brackets/or to mount the licence plate light wiring to the underside of the fender?I'd rather not have to.
Old Nov 14, 2022 | 04:48 AM
  #1438
nulhaq9's Avatar
nulhaq9
Yes.
Old Nov 14, 2022 | 11:40 AM
  #1439
Calif Fat Bob's Avatar
Calif Fat Bob
It's much easier if you do. I took the support brackets with the fender off as one assembly. The 4 bolts near the seat and the fender and brackets come off as one assembly. If you try to do just the fender. There is another bolt underneath AND you risk scratching the fender as it's a tight fit if the support brackets are fully tightened down.
Once the entire assembly is off, then on the bench you can remove just support bracket on the left side to get to the license plate wiring. Once all wired up just re-install the entire fender strut assembly as one.
I've done it twice lol. Once to remove the license plate and then again to add the curved brake light. It's just much much easier off the bike.
Good luck!
Old Nov 14, 2022 | 11:45 AM
  #1440
murphc13's Avatar
murphc13
Good luck!
you guys have the stock licence plate hanging by the left rear indicator correct?
In Europe there's a metal piece attached to the frame with the plate behind the rear wheel.Apologies if ypu have the same.The wiring runs down the swing arm in through the under seat cover I think.
