2018+ Softail Models Breakout
The Everything Fat Bob Thread
Old May 29, 2020 | 05:29 PM
  #911
SCA1's Avatar
SCA1
2nd Gear
Default True Fat Bob 2020 fuel capacity
I know it’s officially rated at 3.5 gallons but when I run it down to fumes I can fit just over 4 gallons in. Have others found this as well?
Old May 29, 2020 | 06:06 PM
  #912
OldMike's Avatar
OldMike
Originally Posted by Bowhunter8607
I had burned 2.5 quarts of oil within 1000 miles before I took it in. Whatever the cause I hope it doesn't happen again after this. This will be the second time in the shop and third top end this bike has had since I purchased it. But the shop has always been willing to make it right.
Hope so!
Old May 30, 2020 | 07:01 AM
  #913
ForceofWill's Avatar
ForceofWill
I've only run it down to about 30ish miles on the range and it fit about 3.1 gals in at the pump.
Old May 30, 2020 | 11:10 AM
  #914
FatBob2018's Avatar
FatBob2018
The tank is listed at 3.6 gallons. I've run it down to fumes, and the most I have ever been able to squeeze in was 3.5 gallons.
Old May 31, 2020 | 09:25 AM
  #915
Justinryon's Avatar
Justinryon
Stage I
Default Front wheel bearing?
Originally Posted by Adamreading
I’ve done 650 Miles now, and I’m hearing a weird noise from the front of the bike (it seems to be the front anyway).
Its a sort of tinny, rasping sound which is there intermittently on acceleration and deceleration. The best way I can describe it is like spinning the wheel of a skateboard, hearing the bearings move.
Has anyone come across anything like that?
Yes. After my break in service I noticed the same sound like a dry wheel bearing. Sound is always there but can't hear at high speeds. I don't think it's the breaks rubbing as noise is still there while breaks are applied.
Old May 31, 2020 | 07:52 PM
  #916
Igor Nabhan's Avatar
Igor Nabhan
4th Gear
Default 2019 fat bob
Hey, guys,
Meet Beyonce.
Painted brake discs centers
Old May 31, 2020 | 08:49 PM
  #917
Gorion's Avatar
Gorion
Veteran: Coast Guard
Beautiful Bike Igor.
Old Jun 1, 2020 | 04:22 PM
  #918
Igor Nabhan
4th Gear
Thanks a lot, Gorion.
Very happy with the final result.
Old Jun 2, 2020 | 08:25 AM
  #919
18FXFBS's Avatar
18FXFBS
I try to fuel up when the reserve lights comes on, but when filling up I found out that if I'm patient after the pumps shuts off if I can consistently fit an extra .6 gallons. I fill the neck filler thing in the tank and then shake the bike a little till the gas goes down,I do this repeatedly until the gas won't go down anymore, This usually gets me about 30 miles before the range display even starts counting down.
Old Jun 2, 2020 | 08:27 AM
  #920
patricioHD's Avatar
patricioHD
Originally Posted by Softaildale
Recently purchased the “Butty Buddy” from JP cycles ($150.)for my friend to ride on. She said it’s pretty comfortable. Was considering Sundowner but this is easier & cheaper plus like the look better. Already have Road Zeppelin which works fine for me.
smart solution for the passenger comfort, could you post more side pictures ?? and whats the passenger evaluation after a ling ride on it?
