RCA's making noise
Old Jun 26, 2019 | 10:58 AM
Biggzed's Avatar
Biggzed
Default RCA's making noise
So I'm a couple sessions in to tuning my new set-up. There is a considerable amount of static/noise coming from the fairing and lid speakers. This is noticeable with the volume at zero. Gets a little worse if I turn up the volume without music playing.
I started fiddling around with the wiring in the fairing and noticed it got real loud when I moved the input RCA's for the DSR-1. The four inputs are right next to each other on the harness, so not a great way to separate them. I'm using 3' Kicker RCA's on those inputs.
Is there a way to shield them? Shrink wrap, electrical tape? Are Kickers known for this? The RCA's going to my amps are Stinger and I don't notice any noise when I move those around.
Zach
Old Jun 26, 2019 | 12:43 PM
InthewindMN's Avatar
InthewindMN
Are the 3’ kickers balled up?
Do they have splits on the barrel so you can tighten them up a little?
Old Jun 26, 2019 | 01:04 PM
Biggzed's Avatar
Biggzed
Yes, they are balled up. trying to keep excess wire length to a minimum (which I'm not doing a good job at). I'm guessing I should stretch them out?
No splits on the ends. Now that you say that, I do remember one of them pushing on pretty easily.
Zach
Old Jun 26, 2019 | 01:34 PM
Tailwind's Avatar
Tailwind
Put heat shrink sleeves on the suckers to avoid the cross pollenization of the electrons and also the keep the securely in place.
T
Old Jun 26, 2019 | 02:15 PM
SBates08's Avatar
SBates08
Actually sounds more like you are describing floor noise due to the DSP.
Old Jun 26, 2019 | 02:23 PM
Tailwind's Avatar
Tailwind
That too. After u get rid of the crackle shix the floor noise will be the next closest alligator to the boat.
T
Old Jun 26, 2019 | 03:10 PM
Biggzed's Avatar
Biggzed
I was wondering about that, but hadn't had the time to look up the term to see if that was a correct way to describe it.
It should be noted that the fairing and lid speakers are both on an SD800.4. I remember RF responding to another thread on here indicating those amps are not very" clean" and will cause this type of issue. I'll have to find that thread and see if there was a suggestion on minimizing it.
I will put some heat shrink on the RCA's. I might also swap them with the Stingers to see if they act the same way. Thanks for the suggestions.
Here's the full set-up in case anyone sees anything that may be an issue I am not aware of.
2007 Road Glide
Sony MEX BT CD receiver
Rockford Fosgate DSR-1
DD VOB3's in gauge holes on channel 3 & 4 of JL XD400/4v2
Crescendo UN6.5 4 ohm on channel 1& 2 of SD800.4
Hertx HCX690 in lids on channel 3 & 4 of SD800.4
Crescendo UN8 8 ohm wired parallel bridged to channels 1/2 of JL XD400/4v2
Zach
Old Jun 28, 2019 | 05:28 PM
sponger's Avatar
sponger
2007 Road Glide
Zach
I to had issuses with an sd 800.4 w/dsr1 and noise. Also had a loud pop at turn off. I tried an sd400.4 and everything went away. I wonder if its just the amp for you as well.
Old Jul 1, 2019 | 11:05 AM
Biggzed's Avatar
Biggzed
I don't have a pop at this time. I went ahead and ordered some 18" KnuKoncepts RCA's for the input side. They showed up yesterday, so I'll throw them in tonight and see what's what. That should help clean up a little wiring. Those 3' were over kill and I've got a rats nest that I have to clean up. Just not sure how to do it yet.
Zach
Loujr28
Jul 22, 2019 10:28 PM
TroubledWine
Audio Systems
Nov 26, 2017 11:38 AM
softhera
Audio Systems
13
Feb 8, 2017 11:20 PM
bowhuntenbob
Audio Systems
Apr 7, 2015 04:44 AM
cmosentine
Aug 4, 2014 05:50 PM
