As I stated before Sidecar cycles made adapter rings for my Rear Pods and my lowers on my Rushmore bike.
Checked them out. They have a couple pics posted of them mounted. Little fugly, but when BT releases the 7.1 brackets for the rush bikes I might give them a shot so I can put my 6.5 titans in the rear.
Hopefully this helps to see what I've put on my 2014 Rushmore Bike. V-Twin/Sidecar custom built adapters using my bike for all areas, including 6x9 Lid Speakers on a CVO. Cutom grills (2 designs).
Thanks for the pictures, they look pretty nice and I bet they work good .that system should sound really good.
I like the pods adapters.. not so much on the lowers though.. what is that gaping hole in the side of the adapter for?
That gaping hole isn't in the adapter. It's built into the OEM faring lowers on all the rush bikes with the cooler. That's where hot air is expelled by the cooling system.
where can i buy that weather proof speaker mesh at and is there a adapter on that front speaker pod?
Hi, I just installed the Sirius Radio module board. I got it from the dealer and it was very easy to install. The module was over 300 dollars. I removed the fairing and I think it was 6 bolts I removed. Once the fairing was loose, I had to make sure i unplugged the headlight from the plug. The entrance to where the module goes has a cover on it. You simply remove the cover and then slide the module into the opening. I put the module in and screwed it down, and placed my antenna in a open space to allow it to pick up a good signal. I plugged in the headlight and reinstalled the fairing. Turned on the key to my bike went to the sirius radio mode and it worked perfect. I have sirius radio in my S-10 truck, my 2009 Jeep Grand Cherokee Laredo, and now i have it in my new 2014 tri glide. The money was well spent and I am happy. if anyone has any questions on how to install it, please feel free to contact me. I found it to be a very simple install. Comes with a great set of directions also.
Hope this helps anyone who is wanting Sirius Radio installed on there bike
Rung (AKA) Rich
I got my bike in February this year. I have 290 miles on my bike and then in May I had major surgery, and got cancer. I am healing up right now, I cant wait until I feel good enough to ride.
Hope this post helps.
DId you have to mod or drill out the speakers at all to fit in the pods and what grills did you use? I'm looking at this exact set up and I really appreciate your feedback. This sounds like the best set-up for the money, now I just have to decide if BT speakers would be worth spending double the price for...
sorry was in laconia all weekend.
i did not have to make any modifications to the pods or the speakers and i did not have to change my grills.
i rode 1500 miles this weekend 80mph on cruise control up to laconia and i had no problem hearing my music. in fact the guy riding behind me on his sgs with stock speakers have to move to the back of the line becuase he could not hear his music since mine was so loud once we got off the highway.
for $400 (amp, speakers, magic box, wiring) i am very happy with the upgrade and it was very simple to install.
