So its time for some Bars!
Old Dec 20, 2018 | 06:32 PM
Chase D's Avatar
Chase D
6th Gear
Default So its time for some Bars!
Hey guys, I have a pretty stock 16' FXDL. I wanna add some taller bars (12"-14"). Im not sure if risers and bars are the way to go or straight up tall T-bars. I know this has been discussed, but I'm looking specifically for the Lowrider. Can someone tell me what cable length I'd need for 14" bars. Plus, I kinda like the Lucky Daves 13 Bars, anybody got em???? Thanks for the help guys!
Old Dec 20, 2018 | 07:03 PM
Bob_fxdb's Avatar
Bob_fxdb
Don't know how tall you are or your riding style, but I think 12-14" is pretty tall regardless and I guess it can cause premature fatigue in your arms and shoulder in the longer rides. Like tall apes. I had a straight up t bar on my previous bike(8") and it was eh, ... On my dyna now, I have 8" riser with high tracker bars that takes it to approximately 10" and my arms are perpendicular with the ground. You have more adjustability with riser-bar setup and hands down, that setup is better then a t bar. More rigid as well. I guess you have more control with a lower bar.
Old Dec 20, 2018 | 09:59 PM
RANGER73's Avatar
RANGER73
It's a personal preference.
I think tall risers and T bars look stupid.
Old Dec 21, 2018 | 12:12 AM
fxdlx's Avatar
fxdlx
Bars clamped in risers are more rigid than welded bar/riser combo?(T bars) I don't think so...
OP if you want 12 - 14" bars the only way to know if you like them is to try them. Lotsa people do like them. Others like low bars.
Old Dec 21, 2018 | 02:02 AM
Mark Faulkner's Avatar
Mark Faulkner
I just had Lucky Dave's 12" San Diego bars and bushings fitted to my FXDLS. I'm 5'8" and the bars sit a fraction below my shoulder height. I've only done about 50 miles with them, but have to say these things are fantastic. Most people recommend the 14", but majority of them are +6'. I took a gamble going with the 12", and i'm glad i did, the bars are perfectly placed for me. Lane-splitting is so much easier with these than with any other bars i've had.
Don't cheap out, buy the bushings too, they make a huge difference.
Old Dec 21, 2018 | 05:09 AM
RANGER73's Avatar
RANGER73
Just to clarify my remark My bike had 4" risers with 10" buckhorn mini apes. This was the stock set up for My model and year.
I didn't like the buckhorn so I went with 10" standard mini apes but the cables didn't reach. So I changed out the risers to 2" but missed the extra height.
I replaced the stock cables with the chrome ones so I went longer knowing I was going to raise the bars.
I reinstalled the 4" risers with the 10" bars and it just didn't look right.
So I got 12" and 14" burs, decided on the 14" with the 2" risers and put the wires IN the bars. that opened up a whole different project of extending the wires.
But not I have the look and height I want. and they're comfortable. For ME. And that's only important to ME.
Buckhorns on 4" risers that you can't see
Standard 10" bars on 2" risers
14" on 2" risers
Old Dec 21, 2018 | 05:17 AM
Bob_fxdb's Avatar
Bob_fxdb
Dude, yeah it is more rigid. Look at the design on both again and tell me. Riser clamp has a larger connecting area than two welded spots(tbar). Risers often has a beefier design than tbar. Tbar just have a weak tube for riser part, proper risers have different design with better bracing. I tried both and you clearly can twist a tbar with less force.
Old Dec 25, 2018 | 12:21 PM
Tall Timber's Avatar
Tall Timber
For the height you've mentioned you'll be able to use Street Bob Clutch and Throttle/Idle cables I have these on my 2010. (8" risers with 4" bars) and are dirt cheap. Brake lines you'll need to go aftermarket (Like Magnum)
Wires - there should be ample in the excess length (currently shoved in the neck)
Risers and bars give you more adjustability and if you get some better bushings there should be zero play.
JakeSmooth
Nov 7, 2014 01:36 PM
that_guy
Sep 28, 2010 09:42 PM
brettnbama
Jul 6, 2010 11:45 AM
transam7969
May 19, 2010 01:32 AM
jeebusroxorz
Jun 7, 2005 07:59 PM
