Primary seal direction
Old Mar 29, 2019 | 06:36 PM
madwrencher's Avatar
madwrencher
Default Primary seal direction
Im replacing the inner primary seal. The one that faces the drive sprocket. The original one is marked oil side and compared to an ordinary type seal looks like its installed backwords but its not. The new seal is a james gaskets and looks different. Like an ordinary type seal. Does the new seal go in like the original seal lip out or flat side out?
Old Mar 29, 2019 | 06:49 PM
madwrencher
03 wide glide
Old Mar 29, 2019 | 06:54 PM
RDHIGH's Avatar
RDHIGH
Install the new seal the same as the old one- unless youv'e changed to a 'dry' primary (like a belt drive primary)
Old Mar 29, 2019 | 07:04 PM
brownie4412's Avatar
brownie4412
General rule of thumb with shaft seals is the flat side faces away from the fluid you’re trying to contain. That seal is there to keep transmission fluid in the transmission. So the flat side will be facing you when you install it.
Old Mar 29, 2019 | 07:08 PM
madwrencher
Thats what i would think because then the spring on the seal would be on the fluid side like the orginal seal.
Old Mar 29, 2019 | 07:11 PM
brownie4412
is it behind the pulley or before it? I may have told you wrong as I was thinking that is the main shaft seal. Either way the same principal applies. Flat side away from oil.
Old Mar 29, 2019 | 07:15 PM
madwrencher
Its the one on the back of the inner primary. It faces the sprocket.
Old Apr 5, 2021 | 08:48 PM
papichuloy2k's Avatar
papichuloy2k
Disregard, I posted in the wrong thread.
Old Apr 6, 2021 | 07:31 AM
Jerry311's Avatar
Jerry311
Spring side in, The flat side with the word (james) faces you when your done.
Z
Oct 12, 2021 08:48 PM
Road Star
Sep 24, 2016 02:15 PM
Eunoterpsia
Feb 10, 2016 11:17 AM
harleydwg555
Sep 12, 2011 07:45 PM
shovelthecoochie
Shovelhead
Jan 31, 2007 02:05 PM
