need help with sert
Old Mar 4, 2006 | 01:33 PM
broke joker's Avatar
broke joker
Default need help with sert
my question is can you use a reguler computer in your house or do you have to ues a lab top? PLEASE HELP! I'am now very computer savey.
Old Mar 4, 2006 | 01:43 PM
PowerCobra98's Avatar
PowerCobra98
Default RE: need help with sert
You can use a home computer if you either bring your bike into the house next to your computer or drag your computer out to the garage with your bike.
Old Mar 4, 2006 | 02:24 PM
broke joker
Well that kinda sucks i don't think i will be doing ether.
Old Mar 4, 2006 | 02:54 PM
bobcowan's Avatar
bobcowan
Check e-bay. You don't need much of laptop for this. Doesn't take much computer power to change a few numbers.
But make sure it has the right kind of connections. From the catalog pictures, it doesn't look like it has a USB connection. It looks like a serial connection??? Of course, for about $30 you can get a USB/Serial adaptor.
Old Mar 4, 2006 | 03:13 PM
Tripper's Avatar
Tripper
Use one of them USB storage thingies. You will most likely need to find a USB gender changer or extension cable. You can then load and run the PCIII program from the USB device. I think that you will also need to have the bike running or power up the unit with a 9V battery. I have not actually tried it, but It should work in theory. Good luck.
Old Mar 4, 2006 | 03:40 PM
JamieWG's Avatar
JamieWG
You need either a home PC or a laptop. Laptop is better because you can ride the bike with the computer in a bag and record data. Others have purchased real long serial cables and run them from the house to the garage.
Old Mar 4, 2006 | 08:05 PM
2005UltraNC's Avatar
2005UltraNC
Got a SERT and laptop, put in Data Mode, disabled standby mode on the laptop (so I could close the lid and keep collecting data)
Problem (happened twice) is that the Data Collection stops - get PCM Sync Failed
What can be causing this error?
I can run in idle and collect data all day - just gets this error when I try and drive the bike.
Old Mar 5, 2006 | 02:44 AM
billybobber's Avatar
billybobber
home computer works great!!! You will have a hard time finding a laptop with a serial port these days. you just need to buy a longer cable to reach the garage or outside. They have cables as long as 50 feet. 2 or 3 of those should work if you need it that long. i only needed 25 feet myself.
I got mine at altex, a computer supply store
Old Mar 5, 2006 | 03:43 AM
JamieWG's Avatar
JamieWG
ORIGINAL: 2005UltraNC
Try setting the baud rate for the com port to 9600. If that doesn't help, then lower the frame rate of the data mode to 10 fps. Could also be your cable. I picked up a USB to Serial cable at Best Buy for $38 and it works fine.
srhen
Apr 20, 2011 05:47 PM
puma
16
Jul 4, 2008 05:31 PM
Mathews2
Apr 7, 2008 12:40 PM
jth81766
Jul 12, 2007 10:05 PM
PowerCobra98
21
Apr 19, 2006 11:43 AM
