Question about changing primary fluid...
Old Feb 26, 2009 | 09:02 AM
  #41
cnydynarider's Avatar
cnydynarider
Originally Posted by mudpuddle
clutch cover on a 2009? ............ Gasket
.........................................Can it be reused? ........ not a good idea
derby cover................ Gasket, or o-ring .........either one works on stock cover
................................Can it be reused? ............. yes
mud
Guess I meant the derby cover( removable cover on primary cover ). Thanks for the info Mud
Old Feb 26, 2009 | 12:34 PM
  #42
mtnlvr's Avatar
mtnlvr
When I had the o-ring I reused it many times. I never had to replace it because it was leaking, just because it was 4 or so years old. Then they gave me the big gasket. I've taken the derby off at least a dozen times and have not replaced the gasket. Just don't over-torque the derby bolts.
Old Feb 26, 2009 | 06:02 PM
  #43
mp's Avatar
mp
The whole point of having a lubricant in the primary chaincase is to lubricate the chain and cool the clutch. The level of the fluid must be above the chain where it engages the clutch sprocket in order to accomplish this. If you get too high a level, it may cause the clutch to slip. If you get way too high a level, the clutch may drag as it tries to work in all that oil. The number of ounces you put in does not matter as long as the correct level of fluid is achieved.
santajim
2014-2024 Touring Models
Oct 16, 2017 05:01 PM
Scott2.0
EVO
29
Jan 20, 2017 05:44 PM
fatbob
Jun 15, 2008 07:41 PM
clayman
Sep 8, 2006 09:51 AM
HDspringer
Sep 23, 2005 09:00 PM
