HELP! Handlebar Change
Old Jul 28, 2009 | 08:58 AM
Stanger's Avatar
Stanger
As others have said, there are a few things to do. Whatever you do, do it right, which to me is to run the wires internal. I have an 06 street bob that I removed the stock bars installed a set of 16"s and I used the stock wiring, no splicing but that ment that i had to remove all the wires at their connectors, take the connectors apart and then run them through the bars, put the connectors back together and then re-connect them. It was not easy, but like you I worked on cars since I was 15 also, so with that experience, the manual (If you do not have the owners manual, GO GET ONE) and the help from everyone here I was able to do it in a weekend. You can do it, but you must take your time and not hurry.
Old Jul 28, 2009 | 09:37 AM
SC-Longhair's Avatar
SC-Longhair
What I did was feed the mesh sleeve through the bars first. Then I pushed 2-3 wires at a time through the bars. Yes, I was able to "push" them all through. I didn't chafe anything and it didn't take that long. Once you get the wires down by the riser area you can grab the ends with a needlenose plier and pull them the rest of the way if need be.
Old Jul 28, 2009 | 10:51 AM
shimmon's Avatar
shimmon
scottylonebull
Oct 29, 2015 10:54 AM
tinker1
Apr 21, 2011 06:12 AM
FunkyNova66
Aug 13, 2009 02:12 PM
cruzin papa
Oct 19, 2008 07:36 AM
HeatherC
Jun 18, 2005 10:14 PM
