Blow by mod
Old Sep 14, 2009 | 09:21 PM
Geezer2's Avatar
Geezer2
Default Blow by mod
Hey guys, a while back I posted about putting a Moom a/c on my bike. Any way I ran into problems with pressure blowing my oil cap out. I'm at it again. I had a machine shop line bore some bolts with a 1/8 hole and the ran tubing to a "t" then down to a fuel filter. Thot I had it whipped. Still blowin the cap. Do you think pulling the filter would eliminate the problem. Am I missin something here? Do I produce so much blow by that I need a filter or just need to keep an eye on the tube end. 05 Dyna SGC. Any help is appreciated. Geez
__________________
Attached Thumbnails Blow by mod-dscf0023.jpg   Blow by mod-dscf0020.jpg   Blow by mod-dscf0016.jpg   Blow by mod-dscf0022.jpg
Old Sep 14, 2009 | 10:12 PM
archergodwin's Avatar
archergodwin
tie a shop rag around the end of the tube and go for a ride. If you're still blow the cap off, there's something else amiss I think.
As I look at it more.... you may be filling the lines up with oil, because they are pointed up, and not enough pressure/air flow to blow them clear. Maybe try with the lines pointed down.
Also, what diameter fuel filter are you using? The filter itself may not be allowing enough air flow if it doesn't have enough surface area....
Just some thoughts there geez...
Old Sep 14, 2009 | 11:17 PM
man4mopar's Avatar
man4mopar
If it is creating that much pressure a leak down test is in order.
Other thought is, does that fuel filter you have allow easy air flow, in short can you blow through it with out much pressure? If it is restrictive I would eliminate it or find a non restrictive filter set up.
Old Sep 14, 2009 | 11:55 PM
ackman1968's Avatar
ackman1968
Damn Frank, was the dog humpin' your leg when you took that third pic? Looks like you had a little trouble holding the camera still. Well that's about all the helpful input I have for ya, sorry I wasn't more help.
Old Sep 15, 2009 | 06:01 AM
Geezer2's Avatar
Geezer2
Now that's funny!!! Now I gotta clean the coffee off my monitor. LMAO Thanks Rick
Old Sep 15, 2009 | 07:05 AM
dmftoy1's Avatar
dmftoy1
+1 on your tubes filling with oil and blocking the flow. They need to run downhill all the way. (Remember that in the stock setup there's "vacuum" on that line.)
Good Luck!
Have a good one,
Dave
PS - Rather than use a fuel filter you might want to check out some of the oil catch cans for this that they have at summit racing ..not sure if they make one that's Harley sized or not . . .but might be worth a look.
Old Sep 15, 2009 | 09:30 AM
ackman1968's Avatar
ackman1968
Anytime my friend.
Old Sep 15, 2009 | 10:09 AM
seniorsuperglideE8's Avatar
seniorsuperglideE8
+1 on the hoses being rerouted, To me looks like the zip tie holding the hose to the backbone could be a little too tight possibly not allowing anything past.
Old Sep 15, 2009 | 07:28 PM
Geezer2's Avatar
Geezer2
You guys rock!!!!! I rerouted the whole thing, got good air movement, took it for a spin and it ran like a scalded azz ape!!!!!!! I may take the scoot in a whole new direction. Rat Rod!!! The whole mod ran about $45.00, including the a/c and filter. May not be for everybody....but I like it.
Attached Thumbnails Blow by mod-dscf0024.jpg   Blow by mod-dscf0026.jpg   Blow by mod-dscf0028.jpg   Blow by mod-dscf0030.jpg
azgrumbles
Jun 22, 2017 11:58 PM
ryanlberg
Jun 12, 2011 11:19 AM
wiseguyups
Exhaust System Topics
Feb 8, 2009 07:59 AM
deadman77
Dec 2, 2007 02:11 PM
Sleeps In Trees
Nov 3, 2006 12:20 AM
