Cams
Old May 27, 2010 | 11:07 PM
  #91
SC-Longhair's Avatar
SC-Longhair
Originally Posted by DCamm94
Sounds great. Nice and low. Love the lope.
Originally Posted by lhcstreetbob
nice job on the pipe it looks good.... that sounds about how mine did at idle with my andrews 54s ..
Thanks, guys. It sounds awesome at idle.
I think I may have found what the issue is with the hesitation. I'll have to run some preliminary checks first before tearing back into it.
My guess is that it's sumping (drowning the crank in oil; robbing power), even though I have oil pressure.
Old May 28, 2010 | 05:57 AM
  #92
mplecha's Avatar
mplecha
I would pull the drain plug on the bottom of the case to check before going back into the motor. Save yourself some work. My understanding of sumping is not that is causes low pressure, but that the pump doesn't scavenge well causing the oil bag level to go low(er). I may be wrong, though. It would rob horsepower, but I'm not sure it would cause sputtering. Perhaps you have an intake leak?
Old May 28, 2010 | 07:29 AM
  #93
SC-Longhair
I did find a thread last night about how to check for sumping. The idea I got from https://www.hdforums.com/forum/engin...que-no-hp.html is that if you are experiencing sumping, oil is being pumped back into the case so the crank is being drowned with too much oil. I may be over-simplifying that concept.
I didn't remove the intake at all so I don't necessarily think it could be an intake leak but I s'pose anything is possibly.
Old May 28, 2010 | 08:54 AM
  #94
Lama's Avatar
Lama
You have adjustable pushrods?
Old May 28, 2010 | 08:57 AM
  #95
SC-Longhair
No sir.
Old May 28, 2010 | 09:03 AM
  #96
paul s's Avatar
paul s
O2 sensors?
Old May 28, 2010 | 09:14 AM
  #97
SC-Longhair
Originally Posted by paul s
O2 sensors?
Eliminated w/ pcIII.
Old May 28, 2010 | 09:56 AM
  #98
JekyllnHyde's Avatar
JekyllnHyde
Hey Vic, I haven't been on here much lately. After getting your text I thought I'd come on and check your progress. The bike looks good. Love the pipes!
Old May 28, 2010 | 10:31 AM
  #99
SC-Longhair
Thanks, George.
One thing that has been puzzling me....a few weeks back when I rode to Murrells Inlet for bike week, and sitting in traffic my rear cylinder was so hot it actually burned my leg. I couldn't touch my jeans.
Well, the issue is the same after the cam swap. Extreme heat would be too lean, right?
Old May 28, 2010 | 10:55 AM
  #100
Lama's Avatar
Lama
You didn't "gap" your spark plugs, did you?
Buy new HD plugs and install them straight out of the box.
I am starting to question that or the advance gear you installed.
