Removing reflectors
Old Mar 30, 2011 | 10:18 AM
FXDLgrl's Avatar
FXDLgrl
Default Removing reflectors
How should I remove the reflectors on the rear fender?
Assume a heat gun, but what is the best technique?
Got them off the front forks but not the rear fender.
I'm afraid of damaging the paint.
Old Mar 30, 2011 | 10:22 AM
DSnoopy's Avatar
DSnoopy
Yep, heat gun and a strong thumb and mine came right off. You will have to get some cleaner to finsish it off and get the residue off.
Some people also use fishing line with the heat gun, which seems to work fine.
PS - I just used a hair blow dryer.
Old Mar 30, 2011 | 10:29 AM
miami's Avatar
miami
Just use Goop Off, buy at Home Depot. A little plastic scraper for leverage and they come right off. You can also use it on that sticker on the front frame..
Old Mar 30, 2011 | 10:43 AM
FXDLgrl's Avatar
FXDLgrl
Will do. Thanks!
Old Mar 30, 2011 | 10:47 AM
Nosaints1's Avatar
Nosaints1
I used a little Goo Be Gone to soak the adhesive then took 8 pound test fishing line and "sawed " it back and forth behind the reflectors...any residue left I used more Goo Be Gone and it cleaned right up and did not damage the paint.
Old Mar 30, 2011 | 10:50 AM
twofish's Avatar
twofish
Big difference between a heat gun and a hair dryer.
Some heat guns can get way to hot.
http://s1125.photobucket.com/albums/...nt=PitStop.jpg
A hair dryer works just fine.
I used WD40, let soak in, warm up reflector and peel back slowly.
Secret is to take your time.
Old Mar 30, 2011 | 10:51 AM
DSnoopy's Avatar
DSnoopy
Good call. I should have remembered to do that last time! argh...
Old Mar 30, 2011 | 11:06 AM
2011 Street Bob's Avatar
2011 Street Bob
I used fishing line first to take them off (like flossed them off, kinda), then bug and tar remover for the remaining goop
Old Mar 30, 2011 | 11:15 AM
Street07's Avatar
Street07
I just did mine last week when I added a sisy bar bracket. Used zippo fluid and some paper towels. Evaporates quick, but I washed it good when I was done.
I've never tried "Goop Off", but maybe next time.
Old Mar 30, 2011 | 11:19 AM
lo-rider's Avatar
lo-rider
Just a word of caution for all you riders who remove your reflectors, blackout your bikes, or otherwise try to make them invisible to cagers, remember the most quoted statement following every MC collision: "I didn't see him." So just be aware that you are giving away some of the odds.
Ride safe.
