Quick Question
Old May 11, 2012 | 06:25 PM
TyeAdair's Avatar
TyeAdair
Exclamation Quick Question
Checked the oil level cold with bike on kick stand, showed low. Got it hot, checked with bike level and the oil was at the cold mark. How low is it?
I found a good Indy thru people at work, I can get a complete tire to tire service for $100 less than the dealer. I want it checked out good by a pro since I just bought the bike. But I want to take it for a good ride tomorrow.
Old May 11, 2012 | 07:06 PM
SuperFastGlide's Avatar
SuperFastGlide
just pour in a little at a time and re-check... I would say about 1/4 to 1/3 of a quart though
Old May 11, 2012 | 07:16 PM
p51bombay's Avatar
p51bombay
You have to check the level on the side stand, cold or hot. Warm it again and check on the stand then adjust while hot if needed, middle of the range, not to the top.
Old May 11, 2012 | 07:21 PM
maddghost's Avatar
maddghost
as long as your in range of the dipstick your supposed to be safe to ride.by what your describing sounds like 1/3 to 1/2 a quart low.
Just do what superfast said.
Old May 11, 2012 | 07:31 PM
TyeAdair's Avatar
TyeAdair
It's 3/4 inch below the cold mark while on the stand cold. I'm pretty sure it's dino from the burn test I did ( rags with syn don't burn easy) but I don't want to add unless I have to because mixing is bad. Is it good enough to run or not?
I really appreciate the input.
Old May 11, 2012 | 07:37 PM
p51bombay's Avatar
p51bombay
Both - if its within the range your fine but there's no reason you can't mix the oils, they are fully compatible with each other. Who told you that?
Old May 11, 2012 | 07:49 PM
TyeAdair's Avatar
TyeAdair
I know that hydrocarbon based oils and synthetic oils don't mix well, if you get enough of a mix it causes the molecules between the two to bond together, resulting in a sludge that can slow movement through the journals on the bearings and other passes the oil makes. I know my engines, but not air-cooled. My first Harley, just don't want to F it up. Maybe the low volume of oil has something to do with it? I know if you mix 5 quarts syn and dino it gets nasty real quick.
Old May 11, 2012 | 08:01 PM
TyeAdair's Avatar
TyeAdair
Now if only my computer would cooperate and let me upload a photo of my new bike. I sure do think she's purrty. Lol, I know, that's a different thread. Thanks guys.
Old May 11, 2012 | 08:36 PM
hjc950's Avatar
hjc950
Who ever told you that stuff was on something. How do you think they make "Synthetic Blends"? What do you think people do when they change from "Dyno, to Syn" or visa versa, tear down their engine to get the oil out so it doesn't Mix?
matthew6279
2014-2024 Touring Models
24
Jul 30, 2017 07:14 AM
mchertel
Oil Archive (no new posts)
May 30, 2015 10:43 PM
UltraClassicElectraGlide
May 2, 2014 03:14 PM
bosscarr
Jun 20, 2013 08:54 PM
jahays32
Jan 19, 2008 02:53 AM
