Headlight issues
Old Jul 8, 2013 | 08:43 AM
jmartin99's Avatar
jmartin99
Default Headlight issues
I have a 2006 Wide Glide. I have had it a year and a half with no issues. Last weekend I went on a ride and during the ride my brother-in-law told me my headlight was out. I switched it to hi-beam and it worked. I just figured the bulb had burnt out on low-beam. The next day I bought a new pair of H4 extravision bulbs and put one in. I then tried it to make sure it was working again and no luck. It was still not working.
I talked to a friend that works on bikes and he told me odds are the dimmer switch is bad. Anyone ever changed one? I am guessing you have to feed the wires down the bars and then under the tank. Is it possible to do without removing the tank?
Thanks!
Jeff
Old Jul 8, 2013 | 12:14 PM
nevil's Avatar
nevil
Check the wires in the headlight bucket on the connector. One might be loose or broken.
If that's not it, open up the switch on the bars and look for a problem. You shouldn't have to remove the tank to get to the wiring, they should go into the frame right behind the neck.
Old Jul 8, 2013 | 12:54 PM
jmartin99's Avatar
jmartin99
I can see where the wires come out of the bottom of the bars and go into the frame right behind the neck...where do they go from there? Ignition switch? Do I need to remove the screws holding the speedometer/ignition switch panel out and get access under that panel?
Also where are the fuse block(s) located on this bike?
Thanks!
Jeff
Old Jul 8, 2013 | 01:49 PM
nevil's Avatar
nevil
The fuses are behind the cover on the left side- it just pulls off. Here is a link for wiring diagrams, just find the one you need on the list.
https://www.hdforums.com/forum/dyna-...-part-1-a.html
Old Mar 12, 2014 | 01:26 PM
jmartin99's Avatar
jmartin99
Ok, I have figured out the wires go to an opening behind the triple-tree neck of the frame accessed from the bottom. There are a bunch of connectors up in there. I have the wiring diagram so I think I am going to remove the tank for easier access this weekend and try to find the break or short in one of the wires. If I play with those connectors, the light will work intermittently.
Is there a tool to remove the individual wires from the connectors if I find the bad one?
Has anyone ever had a similar issue with the wiring in this location?
Thanks!
Jeff
Old Mar 12, 2014 | 01:33 PM
rlchristensenmd's Avatar
rlchristensenmd
If all else fails, try a different new bulb. It is possible that the new bulb was also bad. This happened to me once.
Old Mar 12, 2014 | 02:35 PM
jmartin99's Avatar
jmartin99
I tried three of them. The light works by moving the connectors under the frame neck hence my thought that there is a bad wire down there.
Old Mar 17, 2014 | 08:07 AM
jmartin99's Avatar
jmartin99
So, this weekend I took the bike apart enough to get to the connections under the neck of the frame and took the connections apart and put dielectric grease in each of them and put them back together. It seems to have done the trick. Afterwards I turned the ignition on and moved the wires/connectors around and the headlight never cutout. I hope that is the fix for my problem!
Jeff
WallyWhite
Electrical/Lighting/Alarm
Nov 2, 2017 02:30 PM
jkann1
Feb 17, 2013 06:58 PM
Crossbones
Jun 24, 2012 07:31 PM
ROADKING861
Jul 14, 2010 01:29 PM
Retired_Ted
May 22, 2007 06:58 AM
